Question about Jazz Video Cameras
Jazz HDV180 Camcorder , wanting to know how to take the case apart without damage, want to remove the IR Block filter but not sure how to get started taking the case apart
5 Suggested Answers
robmcd27
  • 423 Answers
SOURCE: Record off the tv.
Hi there and welcome to FixYa.
Hmmm. Ok, I need to know a few things. Does your TV have an RF out jack? Do you have a VCR? And last but not least...does your Jazzy have an RCA type video input jack?
Let me know and depending on your answers, I have a workaround you can use.
Rob
Posted on Mar 04, 2009
  • 17 Answers
SOURCE: I have a Jazz HDV180 digital camcorder and it
Try checking your manuel for specifically named memory card, sometimes certain cameras can only take certain memory card formats.
Hope this helps.
--- JD
Posted on Jan 12, 2011
SOURCE: I need free software for
buy a card reader made for micro sd about 15$
Posted on Feb 22, 2012
stickriffon
SOURCE: how long should it take to format a 8GB sd card in a Jazz camcorder
okay I had the same problem. Turns out you really have to push the SD card in pretty hard. It should be flush with the base (as in not sticking out at all). Did that worked like a charm.
Posted on Mar 28, 2012
How can i take the case apart without damaging it?
Most if not all remotes nowadays are clipped together. Sometimes there is a single screw in the battery compartment you remove 1st. Some have a cover on the IR that needs prising off (Sky remotes). You need a tool called a Spudger to prise the two halves apart. You have to identify which is the inner and which is the outer part and it is difficult to do without damaging it if you have never done it before.
Sep 03, 2014 | Televison & Video
I have a Jazz dvx40 camcorder, ihad it about a mounth or so and whean i turned it on one day IT HAD THE JAZZ LOGO AND IT DIDN'TURN OFF HOW CAN I FIX IT AND SAVE MONEY???
Worth a try - remove batts and SD card. let it sit for 15 min, then install new batts and the SD card. One never knows what a cold boot can do!
Sep 05, 2011 | Jazz DV150 Camcorder
When can I purchase a memory card for the Jazz DVX50?
You can purchase an SD card any time you want, the DVX50 supports SDHC cards but will not support any card over 8GB. I suggest you take the camcorder to Best Buy so you can make sure you are getting the right SD card.
Aug 22, 2011 | Jazz DV152 Camcorder
I just purchased the jazz dvx40 and it powers on but nothing else. i got a 8gb memory card in it and batteries. when it powers on it shows jazz thenn nothing else on the screen and i cant go to the menu or...
I have the Jazz dvx40. When I turn It on all I get is the Jazz logo. I have to take the battarys out to turn it off. I have put new battarys in and get the same results. What can I do?
Aug 04, 2011 | Jazz DV150 Camcorder
I have a Jazz HDV180 digital camcorder and it takes a 8GB memory card. I put a 8GB HP memory card in and it says no card. I have formatted the memory card.
Hope this helps.
--- JD
Jan 11, 2011 | Jazz HDV-188 Camcorder
Trying to format the sd card in my new jazz hdv180 camcorder, but it always just gets stuck on "waiting..." and i can't get it to connect to my computer to format it. Need it for christmas...
Hello
Remove the SD card from your camera and insert it into a memory card reader that is able to read SD cards. From there you can format your SD card and make it usable again.
Good Luck, hope it helps, if so do rate the solution
Dec 21, 2010 | Cameras
Jazz DV151 camcorder didn't come with an owner's manual
You're totally right!
The button with the red circle and a small line through it is the on/off button. The button underneath it with the garbage can is the delete button, the red button in the middle is the record button, and the four buttons around it are the direction keys, and the button with the triangle/square is the play/stop button, so when you're reviewing clips, you can stop and start them.
I hope that helps!
May 22, 2009 | Video Cameras
Record off the tv.
Rob
Mar 04, 2009 | Sony Video Cameras
Video Cameras Logo
Top Jazz Video Cameras Experts
mohamed salim shaikh
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
