Question about Admiral Refrigerators
How old is admiral model hmg 50134 - Admiral Refrigerators
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: feezer seems like it defrosts too long and ice
well its gone wrong now? 25 degrees "above zero?" wow,,, thats cooking!!!! lets be honest,, its 15 years old? its about time you invested in a new freezer you have had your moneys worth out of this one,, and it will cost you more than its worth to fix it up, it realy is time you treeted yourself,, get a new one!
Posted on Nov 17, 2009
AndreaBl
  • 218 Answers
SOURCE: i have admiral refrigerator HMG 21164 and it is
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Posted on Jun 11, 2010
  • 165 Answers
SOURCE: my freezer has ice and fridge does not cool. Admiral signature model HMG 19802. Any ideas
Sounds like you have a defrost problem. First thing check if you fan motor in the freezer is running. You can open the freezer door and press in the door switch and listen to the fan motor. if fan motor is running, you have a problem in the defrost system. if not, you have a bad door switch or fan motor. (not very common)
to test defrost system: Locate defrost timer (under front kick plate) and rotate slowly until you hear a click.After a few minutes you will start hearing crackling sound and see water flowing down the drain line.
if defrost is working, replace the defrost timer. if not, you either have a bad defrost heater or def. thermostat. best think is to replace both.
for more accurate instructions, we need more detailed description of problem
Posted on Feb 02, 2015
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
I need software for a Van Hauser model (50134), where can I purchase it?
Please contact the manufacturer through their Website.
Aug 11, 2014 | Cars & Trucks
Icemaker does not eject ice all the way so it freezes up on unit
The model number you provided is not a valid model number. Please verify the model number.
Mar 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
Admiral- Model HMG 19153 Freezer is cold, but doesn't freeze What's the problem?
Is it set at max? Try switching to fast freeze. it bypasses the thermostat and may help find if it is faulty
Mar 27, 2012 | Refrigerators
PLEASE Tell me how to get the pins out of the rear wheels on my Admiral fridge. Model HMG 621860. They should just slide out but someone opened one side so they would not come out. Thank you Pat A
can't get your model to come up but the pins do not come out or the wheels would fall out . you can replace the pins but removal of old pin will require sawing the shaft . mm ck on the model # so i can help you more . this ref is the same as maytag and jen-air and majic . mm
Oct 22, 2010 | Refrigerators
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Feezer seems like it defrosts too long and ice cubes become wet, ice cream gets very soft, then they refreeze fine. thermometer shows 25 degrees above zero when it is happening. ADMIRAL MODEL HMG 19145, 15...
Nov 17, 2009 | Refrigerators
Not cooling
Replace the defrost timer about $20-30.00. One plug 2 screws. Mine was located on the bottom front behind the grill. (model HMG 24922) . Follow startup directions.
Sep 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
