Question about Thermador Ovens
Thermador oven problems
My Thermador was working fine last week and I went to turn it on and it would not. The display reads "OFF" and there seems to be no way to turn it on...
Any suggestions?
I had the same problem and this solution fixed it ! phew... didn't want to deal with a broken oven during holiday week.
Posted on Dec 27, 2009
Greetings, this JUST happened to me.
The solution was to break the circuit at the breaker panel for 1 minute, reset the clock, and the unit seems to work now.
Posted on Dec 01, 2007
Thermadore oven won't heat
Have you set the clock?
warmest regards
Richard The Repairman
Mar 27, 2014 | Thermador Ovens
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
Thermador SEC301BPSS Electric Single "service Message"
Sometimes, you can reset the panel by turning off the circuit breakers. Look for a linked pair of 40-50 amperes. Turn them off then on. If this doesn't fix it, you will need to change the circuit board...first things first, though.
Dec 21, 2007 | Thermador SEC301BPSS Electric Single Oven
Thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
Nov 29, 2007 | Ovens
Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Aug 18, 2007 | Thermador SMW272 Electric Double Oven
Oven Doesn't Reach Set Temperature
Check the element for burns/wholes this was problem for our.  Easy fix and part is about 35 to 40 dollars.
Nov 16, 2006 | Thermador SC272T Electric Double Oven
Ovens Logo
254 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
