Question about Health & Beauty
How do you remove the 0-LD on start up, on a Propert Digital Scales Model 3030
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
Long sleeve shirt why did you weigh scale reads 0 - LD what's that mean
Are you sure it wasn't 'lb', which is Latin for pounds?
Mar 26, 2016 | Health & Beauty
Propert scales manual
didn't get a solution
Nov 03, 2013 | Home
Propert digital bathroom scales
remove battery. leave out for an hour then put back in. memory wiped then.
Oct 05, 2013 | Televison & Video
Propert Digital bathroom scales only reads half of body weight
If you want to measure accurate weight of your body, then you should to use Omron HN-286 Digital Slimline Bathroom Scale which uses 4 sensors for greater precision in order to accurately measure body weight.
Sep 04, 2013 | LG DVD 5095 DVD Player
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Dec 19, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Health & Beauty Logo
56 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
