Question about Air Tools & Compressors
Inherited an old Sears model 106.154541 oil air compressor. After first use, it blows circuit breaker every time it starts up. Help?
  • Air Tools & ... Master
  • 9,845 Answers
Check the start capacitor on the motor and the centrifugal switch inside the motor to see if it operates correctly.
Posted on Dec 13, 2016
blueextc3221
  • 15935 Answers
SOURCE: where can I find an owners manual for my old sears
CLICK HERE for a PDF version of the manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 09, 2010
  • 1388 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
  • 1388 Answers
SOURCE: keeps blowing the breaker... only 6 months old
This compressor is small however like other brands in this size range draw 13 - 15 amps. Thats quite a bit of power. The compressor has a thermal breaker that will begin to trip if compressor is hot. I am assuming that the breaker that is tripping is the one on the compessor. I have seen many hitachi breakers fail. Easy to replace with generic 20 amp, cost about $10. Before you replace anything, check amp draw with meter, if within specs try to determine what is causing heat.
example:
cycling too many times per hour (check manual for recommended)
low power due to weak circuit or extension cord
using generator for powering compressor (not recommended)
using low quality oil (use synthetic if hot climate)
air leaking from intank checkvalve back to pump
If no reason to overheat then replace breaker on compressor to 20 amp but watch for overheating. Good luck
Posted on Jul 10, 2010
  • 2468 Answers
SOURCE: sluggish on start and blows the breaker on compressor 17amp
replace the start capacitor on the motor body,it is located under a metal cover by loosening 2 screws,it is getting weak,also if you leave this breaker jumped,you will soon over heat the motor windings and ruin the motor
Posted on Apr 09, 2010
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Posted on Nov 26, 2008
When 5hp 25gal air compressor is turned on it blows fuse @ circuit breaker
it sounds like the starting capacitor that is stuffed try a new capacitor cheers
Feb 05, 2014 | Husqvarna Original Sears Craftsman...
Hello, i have a 3 ton 10 seer goodman condensor. It is blowing the circuit breakers, sparks came from breaker box, unit is 11 years old. Can you help?
If you had sparks in your breaker box then you need to call an electrician to look into that. If the a/c is blowing the breaker you may have a shorted compressor and will have to replace it or the whole condensing unit, depends on the price of the compressor vs a new condenser.
Jun 18, 2011 | Goodman CLQ36AR49 Air Conditioner
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a Campbell Hausfeld oil type direct drive 7 gallon compressor. It often works fine but it frequently locks up until the internal circuit breaker cuts off the electricity to the motor. When the...
In our shop we have found the conditions you describe are almost always attributable to the power supply. First, never run a compressor on an extension cord, you are always better off running longer air lines. If you absolutely have to run an extension cord use a least a 12 guage cord no longer than 25 feet. If possible plug the compressor in as close to the circuit box as possible. Lastly the circuit the compressor is plugged into should be rated at least 15 amps, 20 amps is recommended for most compressors. Low amp lines cause the motor to overheat trying to get enough power and usually blow the circuit breaker at the motor and not at the circuit breaker. Lastly, use only compressor oil in the pump and make sure it's not overfull. This will also cause the motor to work harder and trip the circuit breaker.
Dec 17, 2010 | Campbell Hausfeld 2 - Gallon Direct Drive...
Hello , this is Bobby and I have a Coleman Mach rooftop air conditioning unit Model # 8335B8964 when I turn on the unit ,it throws the circuit breaker . I have replaced the starting capacitor and the...
Here's a link to a service manual, with step by step tests to determine whats wrong. I'm thinking compressor shot, but this should confirm, and or help you determine for yourself. Be careful with those capacitors eh !! Read warning in service manual.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Oct 19, 2010 | Coleman Mach 15 Air Conditioner
I have a Sears 33gal vertical compressor. About 8 years old. I keep tripping circuit breakers whenever the compressor is activated and starts to pump. Please advise
either the motor is bad or the pressure relief valve is inoperative forcing the compressor motor to try to start with pressure already in the pump
Oct 15, 2010 | Craftsman Air Tools & Compressors
Keeps blowing the breaker... only 6 months old
example:
Jul 09, 2010 | Hitachi EC89 4 Gallon Twin Stack Air...
Second time compressor tries to fill tank blows braker
The compressor pobably has a faulty unloader valve which bleeds the pressure off that is left in the cylinder when the compressor turns off . The unloader valve allows the compressor to start the next on cycle with the cylinder empty. Trying to start the compressor with the cylinder under pressure causes too much current draw and trip the circuit breaker.
Jul 06, 2010 | Campbell Hausfeld 10 HP 120Gallon...
My porter cable pancake compressor keeps blowing the circut breaker. This is a new problem and it still does it on a 20 amp circut. Help...Thanks
hi!
there are several factors we can consider it comes from short circuited.if you did not rewire the circuit its fine,but if you rewire the circuit and it happen there is wrong connection it may happen every time you power on,check your connection the common line of the motor should as your L1(line 1) and line2 should connect to line capacitor w/c that is your starting capacitor.the pressure switch should be in series connection with line 1 or on line 2
check also the bearing of your motor if worn out replace bearing,because the worn out bearing develop hi ampere it shorted also the electrical system if there is sticky bearing.check also your capacitor if busted capacitor it will also open your breaker besause it can not start up.hope this can help you.
Aug 09, 2009 | Porter Cable C2150 2 Hp 4 Gallon "Job...
Air Tools & Compressors Logo
316 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
