I did a screen rotation on my mac, bt I can't rotate it back becos an error message appears 'cld not load display preferences '. I tried to update the OS but I already have d latest update... pls hlp
sonyspares
  • 89 Answers
SOURCE: LCD Display
The flexible LCD film connecting strip is defective. I think this is fused to the LCD and you need to replace the whole unit.
Posted on Dec 01, 2006
SOURCE: Rotate Video 90 degrees
use VirtualDub... open your video, in the menu Video... Filters... click on Add, select the filter : rotate2, on the Rotation Angle, write : 270, you can test the angle with the preview button. You can alors enter : -90 instead of 270. Check the 'Expand frame to fit'. You can preview all the option, before converting the videos. Click ok...ok until you have the main windows.... Make sure you selected : Full Processing mode in the menu Video.
Posted on Aug 11, 2007
thassall4295
  • 91 Answers
SOURCE: no files on sansa m 240 but appear on computer
Try formatting your mp3 player which might fix this problem. Also do some updates from the manufacturers website. This may be a known bug which your mp3 players manufacturer may have found and made a new driver version for.
http://www.sandisk.com/driverdownload/index.asp
To format follow these steps below:
First go to "My Computer" - now look for your mp3 player usually named under for example "Removable Disk F", when you've found it "Right-Click" on it then click on "Format", when format is complete try after that.
Any further problems leave a comment on this page and i will get back to you.
Good luck. Hope my solution was helpful.
Posted on Nov 09, 2007
tom19511
  • 1601 Answers
SOURCE: Update driver for UMAX Astra 2200 for Mac OS X
8.6 -9.1 is the lastest available.
Sorry, your scanner is too old for newer versions of MAC OS
http://umax.com/download/index.jsp
Posted on Nov 17, 2007
  • 4234 Answers
SOURCE: sony 5 disc dvd player says c 31 00
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Thanks,
Dan
Posted on Mar 02, 2009
Dell 2208wfpt settings for portrait rotation?
Andrew Scharlach,
Are you changing the rotation using the ctrl+alt+right arrow. left arrow or down arrow? That is how i change the rotation on the screen. If needed lower the resolution in the display settings in control panel.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 24, 2015 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Dota games
Hello there!
Unfortunately,Dota 2 was only available to Windows and Ubuntu.You should try redownloading it,since it's now out for Linux(Your OS).If that doesn't work,you might aswell be updating your graphics driver from
Support.amd.com
Cheers,
Aldo.
Aug 01, 2013 | ATI Computers & Internet
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Monitor rotation from MacBook Pro
Go to system preferences > displays, then there's an option to rotate the display. You'll also need the corresponding cable to connect it. Enjoy the mac!
Dec 11, 2012 | Samsung SyncMaster 2493HM Monitor
How do i turn my screen back the right way
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
Dec 02, 2011 | Toshiba Satellite C655-S5068 Notebook
My screen is on sideways and i cant put it back the right way
Tips & Warnings
Dec 02, 2011 | Computers & Internet
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
How do I rotate the screen when I rotate the Acer B203w
For Windows XP -- within the control panel, click on Display Icon and the following screen will appear. I have 2 monitors (Laptop and HP L1925 monitor). On the display properties screen, near the top of the screen, click on the “Settings” tab. When the “Settings” screen displays, select the “Advanced” button near the bottom of the screen.
The “Plug and Play Monitor …” screen will appear as shown below. From this screen, click on the “INTEL(R) Graphics Media Accelerator Driver for Mobile” tab near the top of the screen. Note: Tab stretches the full width of the screen.
The "Plug and Play Monitor ..." screen will change to show Intel Graphis Media Screen. From this screen click on the “Graphics Properties” button near the center of the screen.
The screen will change to show the graphics properties. Note, the screen actually comes up with “DISPLAY SETTING” selection (in dark Blue on the Left hand side of screen). To change Display settings click on the words “DISPLAY SETTINGS” (left side of screen) and the screen will switch to show Rotation options. On the top of the screen, select the “Monitor” you wish to change by clicking on “Monitor” button. Next make sure the “Enable Rotation” box is check on the right side of screen and then click on “90”. Your monitor should rotate at this point to portrait. A message will appear letting you confirm if you wish to keep this new setting. Specify yes to keep the new setting.
This should do the trick.
Joe Buus
Jan 29, 2009 | Computers & Internet
 Grubhead
Grubhead
