Question about Garden
How do I turn the down presure off on a snow way 29hd snow plow?
  • 104 Answers
SOURCE: snow plow wont turn right
To turn Left you need two cylenders. I think you only have one. Any one cylender will have three wires and a ground. The ground is always connected to the vehicle ground. The other two to the Single pole double throw switch. TOne wire and a ground runs the pump one way, the other wire and the ground runs the pump the opposit direction. For left and right you must have a similar pump, motor and wiring.
Posted on Feb 07, 2009
  • 47 Answers
SOURCE: battery goes dead when plowing snow
change alt. have it check at autozone free of charge
Posted on Dec 26, 2009
  • 454 Answers
SOURCE: my snow plow keeps lowering to the ground after i
You have a hydraulic valve leaking in the pump.
Posted on Jan 28, 2010
mickey813
  • 472 Answers
SOURCE: riding mower snow plow
go to manuals online put in model number off the snow plow and it will show you the manual
Posted on Feb 12, 2010
  • 55 Answers
SOURCE: 2006 snow bear plow,
Yes, Check where strap or chain is mounted to winch. It could be loose or have dirt or oil on it something to make it slip.On mine there's a brass piece that raps around the shaft, It got lose and dirty so I cleaned and tightened it. If you pull motor off winch to check gears [don't use gear] when reassembling it's too thick when it's cold. I used white spray lube. Hope it helps!
Posted on Jan 22, 2011
While driving down road my western snow plow is rocking all over.
not good or safe! check all mounting pins and frame mounts. A lot of force is on snow plows and the frame mounts often need to be welded up. I imagine it is the whole unit and not just the plow.
Mar 12, 2015 | Cars & Trucks
Curtis snow plow
solenoid is leaking replace or reseat
Feb 05, 2014 | Curtis Garden
Snoway plow will not go up or down
I just purchased 3 months ago a snow-way series 22 and it has lost signal and won't reconnect, any ideas how to fix it?
Dec 28, 2012 | Ertl Snow Plow Toy Trucke
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
Snow Bear Winch..... Will not pick up plow at times. Motor seems strong drum will not turn,,,slips. Is there a replacement part available without buying an entire winch? Thanks
Hi there, I had the same problem, my winch has a chain to lift the plow.I put oil on the chain to keep from rusting and thats what started my troubles.So I took the mount off that holds the chain on the winch and there's a brass piece that is squeezed behind it.Cleaned and tightened it and works fine now. If you take motor off winch to check gears[ DON'T USE GREASE] when reassembling! When its cold it doesn't want to turn, just use motor oil or spray lube
Jan 19, 2011 | 82" TruckSUV Snow Plow
Sno-way plow will not go up or down
I just bought a Snow-way series 22 plow 3 months ago and the remote has lost signal and get it back to responding, any ideas
Dec 13, 2010 | Ertl Snow Plow Toy Trucke
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
