How often does the infared sensor go bad on the tv. I have had my tv about 7 years?
  • Televison & ... Master
  • 9,771 Answers
Not very often, if ever. Here's a way to test the remote for operation. Turn on the camera on your cell phone. Aim the remote at the camera and hold down any button on the remote. If you see a flickering light coming from the remote, the control is working perfectly. Now hold down the button that doesn't work. If the light flickers, the TV sensor is bad. If the light doesn't work on the suspected button, then the remote is toast, but repairable.
Posted on Dec 13, 2016
I have a 2005 GMC Envoy with factory tv and cd player. Is there any difference in infared head phones and what would you suggest for teenagers?
Infared head have the best sound as there is less interference. Most factory system are one way or the other, infared or fm.
Jan 28, 2010 | XO Vision Wireless Infrared Stereo...
Emerson EWF2703 27" No remote will work on tv. Is it expensive to repair, I feel it must be within the tv and the receiving end of the infrared sensor. Any idea of the cost to repair it. Or any other ideas...
Could be your infared sensor has gone bad.or it might just need to be reset back to factory reset. If it was unplugged for a while before this problem arrose then then the reset is probably your solution. Hope this helps.
Jan 03, 2010 | Emerson EWF2703 27" TV
We have 2 Sylvania TV's. The remotes work on one TV but the other TV no longer recognizes the remotes. It gradually seemed to lose reception of the signal from the remote. Any ideas?
The tv has a infared remote eye located at the front panel. It is possible that the remote eye sensor has gone bad. You could try cleaning the remote eye lens. There might be debris that got inside the remote eye housing and is blocking the sensor. You could also try installing fresh batteries in the remote.
Sep 26, 2009 | Sylvania SRT2319 TV
We have a proscan tv and the remote dosent work at all
try a universal remote or replace with new origional remote you can order. If no remotes work on tv, your infared sensor may be faulty
Aug 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Infrared signal connects to tv etc but then dies
If the infared reciever on the reciever is that bad you might consider getting a Infared repeater (look on ebay, they are like $50. they work pretty well
Feb 06, 2009 | Kenwood VR-309
Need to replace infared eye on 36AF41 Toshiba TV
Yes, the back needs to be removed and the main board slides out to gain access to the IR sensor. Usually, the sensor itself is fine, the connections can get broken. Try resoldering the 3 pins for the sensor first. That alone may resolve the problem.
Keep us posted.
Dan
Jan 30, 2009 | Toshiba 32A41 32" TV
Ice maker won't stop making ice
souonds like that sensor has gone bad, doenst know its full and contionues to make ice. youll need to repalce the electronic board.(they come as a kit both emitter and reciever,)
Mar 08, 2008 | Kenmore 55693 Side by Side Refrigerator
The tv sensor is not working on my 42" lg lcd hdtv
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
Feb 12, 2008 | LG 42LC2D 42 in. LCD HDTV
My remote control does not work
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Jul 06, 2006 | Toshiba MD20FN3 20 in. TV/DVD Combo
TV changes channels itself
Have you checked to see if any of the front panel buttons are depressed and stuck??? this is a big problem these days?? I have also found the infared remote sensor to be bad on some sets that do crazy things all by them selfs.. A funny storry once i had was a customer called me after her mother called some goast finders as her maggy projection set would go on all by itself andf the channels would change and the volume would go up and down all by its self. funny thing I had a set just like thast in the shop at the time with the same problem and I scoped out the output pulse from the infared reciver on the set and that was putting out noise on the data line and caused the set to eratacly do all sorts of weird stuff. get the point?? its a stck button or the remote sensor is bad.
Apr 01, 2006 | Bush WS6671 28" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
