Ruud furnace, model UGRA I need to trouble shoot the fan control board.
  • 946 Answers
Does it have the flashing light you can view thru the peephole and count the flashes? They will give you an idea.
Is the fan coming on? Describe the problem. don-ohio
Posted on Dec 31, 2016
I have a RUUD ugra-07emaes. I've been trouble shooting for a few days now. It seems like I'm chasing a ghost in the machine. I think i narrow it down and when i apply the suggest fix a new issue seems to...
you got a bad board because a spark means a jump where the small surge of electric has no place to go. check the gas valve relay anyhow and see if it is bad if so get another one if not geez you might have to get another board
Oct 31, 2014 | Cars & Trucks
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Feb 11, 2012 | Ruud Heating & Cooling
Rudd Furnace Model UGRA-04EMAES Gas valve will not open
If the Igniter is not glowing, then the gas valve would not open to push out the gas. This indicates a Weak Igniter and you need to replace that.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 20, 2010 | Ruud Heating & Cooling
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
Aug 10, 2009 | Heating & Cooling
Ruud achiever 90 plus gas furnace not blowing any heat
These new furnaces are trouble. Ive been in the htg trade for 25 yrs. The fan is running because they are now controlled by a timer instead of a temperature control. Rather than sensing a preset temperature and turning on the fan, it comes on by a preset time. Couple of things, does either of the doors have an inspection window? most newer furnaces have what is called a smart board. The board will flash a trouble code. ie: 1 long 2 short etc. #1 turn your thermostat to off, youll need 2 people for this! Go to the furnace, If it has the above mentioned inspection window ( usually about 2" round) while peering through the window have someone turn the thermostat to about 80 degrees. Let the furnace cycle and see if it flashes a code. If it does the codes are usually on the bottom door, May be on the inside. The most common cause is either a bad transformer, bad hot surface ignitor or pressure switch failure. Further questions feel free to ask. Steve
Dec 21, 2008 | LG LW1200ER Air Conditioner
Ruud heater will not light consistently
Your furnace is going into a lockout condition, cycling the power resets the circuit board and it starts over. I will need to know approximate age and model of your furnace, it sounds like you have need to clean the flame sensor rod. However i need to know what i am working with.
Dec 18, 2008 | Ruud UBHC Air Conditioner
Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM GAS FURNACE
replace the gas valve....test for 24volt at the gas valve input.  if you have this then it's a def gas valve relay not working.
Dec 09, 2008 | Heating & Cooling
I have a Ruud Silhoulette Model #UGPJ-12EARJR Furnace. My Carrier A/C unit comes on but the fan blower motor in the furnace does not.
Could be a bad fan control board or the motor. Need to see if you have power to the motor from the board
Jul 06, 2008 | Ruud Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
