Question about Meade Optics
I have an 8" Meade LX90 ACF with GPS. The RA drive is not working.
When using the Autostar handbox - the arrows slew the scope up & down, but not left/right. Even when Easy Align is selected it'll slew up to find Vega but not left/right. The scope was an 2nd hand ebay purchase, and after initially working ok, the RA drive refused to cooperate. I took a long drive to Kent to have it fixed, the telescope technician plugged in his battery supply, everything worked ok. Purchased the same power tank, everything ok for 4 months. Now, the same old problem. Had the heating on over night, everything fine again, until the week after. What does this sound like to you? I don't think it's Autostar related, sounds more like a loose wire, maybe???
4 Suggested Answers
SOURCE: MEADE LX90 TELESCOPE
Had the same problem. Took it to a dealer and we put a new controller on but the funny thing was that my old controller worked fine on another scope but it would not work on mine. Agreed with "Guest" above - Mead's after sales service is bad.
Posted on Apr 08, 2008
SOURCE: i have a meade lx90 8inch 3 years old with
This is called "rubber-banding". Your scope needs to be re-trained.
So, setup a target during the day at least 100 feet away from the scope (200 feet would be better, Calibrate motors using the same power source you use at night, and Train Drives. Later after dark, do a Calibrate sensors on Polaris.
You should train drives about once per year, and calibrate sensors about twice per year.
You may want to update the firmware before you Train Drives. The latest version is 43Eg available on the Meade.com web site. You with need the Autostar Updater Software also available on the Meade web site under Customer Service---- Downloads. Version 5.9
www.meade.com
Posted on Oct 27, 2009
Testimonial: "thank you very much for your excellant advice.being the only meade owner in our club help is very scarce --once again many thanks"
SOURCE: Meade LX90 GPS - When the telescope slews to a
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Posted on Mar 04, 2011
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
Blank screen no screen output at all after a software upgrade
Did you update the 494 controller improperly with 497 controller firmware. You must use this updater software :
http://www.meade.com/support/auto/Au2ver59.exe
Hold down the ENTER key and the scroll down arrow key at the same time abd power on the scope. This will place the hand controller into the SAFE load function and you will be able to do another update.
If you plugged or unplugged the controller cable with the scope turned on you may have burned out the controller. Contact Meade:
http://www.meade.com/support/index.html
Apr 26, 2010 | Meade 494 AutoStar Telescope Control Unit...
I have a meade lx90 8inch 3 years old with autostar 497--when i try to raise the scope up it keeps drifting down also having problems with intermitant slewing on set up-both motors working ok
www.meade.com
Oct 27, 2009 | Meade LX90 Telescope
I have a frozen autostar 497 handbox, can it be reset or saved? While doing an update, the updater program window asked if the handbox was in ''safe mode'' (I think it was something like that), I clicked...
Turn off the scope and plug in your computer update cable.
While holding down the ENTER key and the Scroll DOWN ARROW key on the bottom, turn the scope on.
The controller will go into Safe Load mode-- redo your update again.
Oct 12, 2009 | Meade Optics
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar.
Oct 08, 2009 | Meade Optics
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
No power to the autostar
You may want to try a new cable to the Autostar.
Nov 02, 2008 | Meade LX90GPS: 10" LX90 GPS Telescope
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Meade Autostar handbox
removeformat.gifBecause this is a new purchase i would suggest getting the handbox replaced under warranty. If the guy was rude, then mention this to their management. There have been quite a few prolems with meade gear on our site here. Handbox included.
If you are up to it you can open it up. if so inspect the board for damage, shorts or loose solder joints. Some of these things can be repaired, some cannot. On this last statement it would seem sensible to get the replacement then start again from scratch. I have found about 7 recent problems with this unit, so be aware this is not a fault free unit.
nettiser
Sep 15, 2007 | Meade 494 AutoStar Telescope Control Unit...
Optics Logo
81 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
