Question about Home
LL appears in the inside temp. location on the clock. What might cause this?
My Hammacher Schlemmer Projection Alarm Clock and Weather Monitor will not project the outside temp. It only projects the inside temp. How do I change? Also, can't change the time zone.
No solution but to return it...very annoying product but yet I like the projected display, very sharp and bright. The replacement was much better, it loses connection with outside transmitter often..but occasionally we see the outside temp
Dec 28, 2013 | Hammacher Schlemmer The Projection Alarm...
F1 code on GE Profile Range. Model # JGSP40AES2AG Oven Sensor checks 1100 OMHS at 79 degrees and drops to 980 when cooled in 66 degree water. Oven temperate is maintained when oven is used. F1 code...
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the electronic control/clock assembly. You can try ebay for a new part and check this video for repair:
Please get back to me if you have any other questions.
Kevin
Apr 15, 2011 | Ovens
What causes the temp reading of LL.L?
The SkyScan temperatures only register a certain range, typically -4F to 158F. If it is below this range, it will read LL.L and above it will read HH.H. However, I have been having trouble with mine reading the correct temp, so I often get very whacky numbers, and LL.L is becoming more frequent. Hope that helps!
Dec 30, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Shift 3 Projection Alarm clock remote cannot open
Once the batteries are installed in the remote the temp will appear in the LED screen. Now you are ready to link signals between the main unit and the remote. Simply remove one of the two triple A batteries from the main unit and then replace. You should then see what appears to be a flashing object shaped like a kite with a tail while the two units link up. Then you should see the temp reading at the remote appear in the LED readout at the main unit. By the way there is also a very small reset at the top of the switches on the back of the main unit that can be depressed with a SMALL pointed object like a scissor point or safety pin point.
Feb 06, 2009 | La Crosse Projection Alarm Clock with...
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
