Question about Dell AS500 Sound Bar Computer Speakers
Broken switch on dell as501
How do I open the Dell AS501 speaker to take out the broken on/off switch ?
First you need to unscrew 7 (seven) screws on the back. One screw is hiding under white label. Housing is assembled from two parts, front and back. Both parts are then glued together. Glue is not so strong as epoxy or fast cyano-fix glue. With two medium size -- (minus) screwdrivers start to put apart two parts of housing. Start on the top, under the latch. You need to put screwdriver between two parts of housing. Edges overlap in a way that edge of back part of housing is on the top, front edge is under. When you get first crack you need to use second screwdriver to help first one. With both screwdrivers need to go around all housing. You will not find any latches on the way.
Posted on Jul 08, 2012
You already found how to open it?
Posted on Dec 25, 2010
The Dell AS501 doesn't seem to want to connect to my Dell E196FP Monitor.
If there is a power connector for the soundbar, it should be on the bottom of the monitor where all the other connectors are located.
Mar 25, 2014 | Dell E196FP 19" LCD Monitor
How to remove sound bar AS501
There is a clip near hook by pushing it.It will unlock the bar and slide it to right in horizontal position but in tower position it will slide to left7_22_2012_10_18_04_pm.jpg
Feb 17, 2011 | Dell AS501 SoundBar 2 Speakers
Blue light comes on AS501 Flat Panel Speakers, but there is no sound.
After reinstalling/installing an Operating System you can lose the Audio Drivers or sometimes they just corrupt.. Try reinstalling the Audio Drivers from the disk provide with your P.C./Laptop. If you no longer have the disk just visit the website of the makers of your P.C./Laptop or Motherboard and download the Audio Drivers from there, after that install them.
Thumbs up please if this works for you, thanks.
Aug 26, 2010 | Dell AS501 SoundBar 2 Speakers
Where does round plug go in connecting?
the round connected, i believe is for the power adaptor
May 06, 2010 | Dell AS501 SoundBar 2 Speakers
My Dell AS501 does not produces sound. I have
make sure the power is hooked to the back of the monitor, and that the speakers are hooked into it. make sure it is switched on and volume is at 50% or higher. if it still doesnt work, try hooking an mp3 player to the speaker jack. if they work, its the computer. if it doesnt work, replace the speakers.
Dec 12, 2009 | Dell AS500 Sound Bar Computer Speakers
How can I open the Dell AS501 sound bar to replace a broken switch. It doesn't open after the screws are removed.
There is another screw hidden behind the white bar code label, and the whole thing is also glued. You need to use a lot of force to pry it open. It is not worth it to fix it, just buy another off Ebay for around $15 shipped...
Nov 20, 2009 | Office Equipment & Supplies
WHST ADAPTOR DO I NEED FOR MY SPEAKERS
Connect the green one to the laptop audio out connection and the other one to your laptop where you connect the charger.
Jun 22, 2009 | Dell AS500 Sound Bar Computer Speakers
Speaker Bar connection
There are 2 placces on the underside of the monitor for the speakerbar to slide into. For that model You will probably need the external power supply.
Jun 22, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Dell AS500 Sound Bar Computer Speakers Logo
942 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
