I have the single unit heater that hooks directly to the propane botel it won't stay it after letting off the lighter button has full bottle gas.
  • Heating & Co... Master
  • 3,284 Answers
Sound like the thermocouple needs replacing
Posted on Dec 13, 2016
I have a Heat Dragon Reedy Heat 50 RLP50. It won't stay ignited when I let go of the knob after 30 sec or longer.
will need to check and test thermocouple --valve unit --and that your hooked up correctly propane [lp] to a propane unit or natural gas to a natural gas valve unit --also check flame is contacting the thermocouple
Dec 20, 2016 | Heating & Cooling
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
Is there any difference in bottle gas heater and natural gas heater
by bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
Apr 23, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
I want to connect the unit to the main propane
First of all I am only concerned with your safety when I ask you to only have a qualified service tech install this heater for you. PROPANE is very dangerous if you aren't well trained in the operation/installation of gas fired equipment.Natural gas isn't quite as dangerous as it is lighter than air and will dissipate easier. Propane is heavier than air and will pool in the lowest spaces and collect there. To answer your question, yes most regulator can be adjusted, but again only by a qualified service tech because he needs to adjust the gas pressure to the equipment rated gas pressure specs. Again I am only concerned for your safety.
Nov 28, 2009 | Dyna-Glo RMC-8001SS Heater
Gas vavles is letting propane gas through the gas control vavle.
If you have propane you better not mess around! with nat gas its lighter than air and drafts or flies away if it can.
not so with propane , its heavier than air and stays down low!! and the most explosive situation is 10% gas/ 90% air !!!! so a small leak??? there is no such thing with propane!! turn off all valves to it and get it fixed by expert this is one repair a handyman should never do!!
Aug 23, 2009 | Cozy Enclosed Front Console Heater 20,000...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
