Question about The Video Cameras
Liquid image 727 camera will not record or do anything. the red light is on and will not go out. what is the problem.
Stuck in video Mode on startup - Liquid Image VideoMask 310
I realize your post is several months old, but since no one else answered, here goes. With fresh batteries in your camera, attach the USB cable to the mini connection hidden below the screw-on-cover on the top of the camera body. Make sure you have the mini side of the USB cable attached correctly to the camera. Be careful. It will fit both ways but only works for one of them. Don't turn the camera on. Attach the other end of the USB cable to a USB port on your computer. The camera should activate (The LED should come on. Blue first, then red and stay red) and you should see "USB" in the LCD display on the back of the camera. Your computer may indicate new hardware found or may ask you what to do with files on a USB storage drive, which is what the camera will be read as. Do what you need to do to answer your computer so it will recognize the camera. Afterward, you should be able to transfer your memory card contents onto your computer. Once you have confirmed transfer, format the camera storage card so it is empty for the next round of photos/video. Hopefully you have this working by now, but just in case someone else has the same issue.
Jul 30, 2017 | Liquid Image VideoMask Series 310 + 4GB...
Red flashing light in the corner on canon rebel eos t3i
The flashing red light in the bottom right is the indicator that the camera is writing to the memory card. If you have shot in RAW this will take a little longer than recording a jpeg as the RAW files are larger. While this is happening the screen will go blank for a short time.
Jun 08, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Jan 26, 2010 | Pure Digital Flip Video Ultra Camcorder
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
Every thing works but cant see anything threw camera lens cover is open i see all menu options but no pic it records sound but no video any help TIA
Seems your camera Sony DSC-T1 got bad ccd imager problem, as camera does not show live image to record and shows previously stored pictures fine in playback mode.
Sony will repair it free of cost. Click Sony CCD Imager Support for details.
Jun 21, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Need to know where the record button is
I hve the same one. Look at the front of your camera where the lens is facing. Look under it and there is a part where it flashes. Look under that and you'll see a small red rectangle. Press it and it will record.
May 18, 2009 | Aiptek A-HD 720P Flash Media Camcorder
The image is getting blurred
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Can't turn on my camera!
I have a link and some information I found on the video option to your camera. This link is for the manual located on
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Feb 27, 2008 | HP Photosmart R707 Digital Camera
No image during replay -- sharp mini dv VL-NZ50
a cleaning cassette ( the red ' x ' ) will help : if cleaning works ? retire your old tapes , or your heads may need replacement - sooner rather than later ;
Apr 06, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
No pictures recorded/black screen
it seems that shutter blades are stucked and are not working. when you say shutter is fully open i think you are talking about the lense cover, not the internal shutter assembly. the red light is the indication of OUT OF FOCUS SUBJECT OR FLASH NOT READY. if the shutter blades aare not open the camera would not be able to do the focusing and will flash the red light thus you would not get any image. contact the repairer.
Jun 20, 2006 | Kodak EasyShare LS443 Digital Camera
Video Cameras Logo
Top The Video Cameras Experts
Are you a The Video Camera Expert? Answer questions, earn points and help others
