Question about Sennheiser Audio Players & Recorders
Need more volume from sennheiser rs175 - Sennheiser Audio Players & Recorders
I cannot control the volume on the headset...only on the TV. Any thoughts as to what I can do?
You could try taking out the batteries for a minute.
If that's no help then contact Sennheiser customer support:
Jul 23, 2016 | Sennheiser HDR 170 Wireless Headphones
Hi. Suddenly the volume controls for my Sennheiser i300 headphones for iPhone have stopped working. Any ideas? Thanks in advance Paz
I thought this was another example of the proprietary world of Apple, whereas any non-Apple made or certified headphones/headsets with mic and/or volume control will not work with an iPhone or iPad (I am not sure about iPod). It took me many headsets to figure out what was going on. However, your headphones seem to be made for iPhone and sold in Apple stores. If this is the case, I will go back to any Apple store and talk with the tech people there about your situation.
Oct 23, 2014 | Sennheiser Audio Players & Recorders
Why have I lost volume in one ear
there will be some loose connection in wire...or else u may have dropped down the earphone....maximum it will be wiring problem....
Aug 20, 2014 | Sennheiser Genuine Cx270 Cx 270 In Ear...
It won't work on my laptop. :(
There is no technical reason why the Sennheiser shouldn't work with a computer.
Here are some general instructions re using mics with a computer
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
If you still don't get enough volume then you may need a pre-amplifier to boost the signal
Feb 17, 2011 | Sennheiser E815S Professional Microphone
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
Nov 06, 2010 | Sennheiser VMX100 Bluetooth Headset...
Sennheiser VMX100 not working with G1
make sure you oreder your bloothoth from htc and its for the g1 next time
Jan 23, 2010 | Sennheiser VMX100 Bluetooth Headset...
I can't get sound from my p c system,and tried the configuration volume from the control panel and it wouldn't move.
Sep 03, 2009 | Sennheiser MM200 Premium Bluetooth Stereo...
Unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Dec 02, 2007 | Sennheiser RS 110 Consumer Headphones
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
