Question about Vacuums
I'm buying my wife a vacuum. she wants light weight. we have dogs and cats in our home. she does not need attachment she said. can u help me pick one that will meet our needs? thank you for your help
    Top Expert:
  • Vacuums Master
  • 8,304 Answers
I think your best bet is to look on the internet that way you will be able to see and read what would be best for you wife.
Posted on Dec 12, 2016
It is not working as well as i expected it to, I have 2 dogs it does not pick up dog hairs.
We have a long hair cat and dog try hoover best and end up getting a Dyson and it was worth every penny
Apr 28, 2016 | Hoover Vacuums
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
The alarm on my machine keeps sounding; even though I have cleaned the filters, emptied the dust bucket, its driving me mad as I rely so much on this machine; with dogs, cats and children and a farm h
Please check the suction on your machine? Is it strong? It may be that you have a clog, particularly since you have dogs, cats and children!
It suction is fine, have you checked the rotating roller brush? If the point of pickup is poor on your floors, you may need to check your belt. You may have picked up a large object that has affected the tension in the belt. Visit here for your belt: http://www.crucialvacuum.com/LG-Kompressor-Vacuum-MAS61842501-Belt-p/lg_vacuum_belt_5eph271.htm
Oct 18, 2011 | LG Electronics Kompressor Pet Care Upright...
My husband uses talcum powder liberally and we have a long haired white dog. I barely get 12 months out of vacuums. Have had (2) Miele Dog & Cat vacuums with additional filters attached - can you...
You can build a homemade soot trap like what oil burner service reps use. Please refer to the drawing. You start with a widely availabe bucket with an airtight lid (Home Depot sells one in their trademark orange color for example). Along with the bucket, you will need about 30 inches of PVC pipe - ideally you will get the diameter that matches your vacuum cleaner hose attachment. "Schedule 40" PVC pipe will work fine. This refers to the less expensive thickness of pipe- any home improvement store rep can help you with this, and if you bring in your hose and explain what you need to do they will gladly help you out! Finally, you will need a tube of silicone RTV sealant. Cut two holes matching the size of your PVC pipe into the lid of your bucket, and cut the pipe into two sections- one that will sit three to four inches from the bottom of the bucket, and one that will sit one or two inches below the lid. Put them into position and use the RTV sealant to hold them in place and also provide an air-tight seal. On the lid, label the side that has the long pipe INLET and the side with the short pipe TO VACUUM. This is CRITICAL so make sure you do it! Labels, paint, marker, crayon- whatever. Label them NOW!
Finally, you need a section of flexible plastic hose to connect your trap to your vacuum. Six to eight feet should work fine. You will have to be creative to make sure the connection between your new trap and vacuum are air-tight, but IMHO this adds a little adventure to the project... you want something easy to attach and remove, and by no means do you want to do anything that prevents you from taking your new trap off and using your vacuum normally. Hardware stores are bursting with all sorts of adapters and stuff! The same goes for the inlet side of your trap, but hopefully you matched the pipe up to your pickup hose to where it makes a nice tight fit and works without adapters.
After the RTV cures (about 24 hours) and you are satisfied that everything is in order, you are ready to use your soot/dust/fur trap! Fill the bucket about 1/3rd of the way up with water. Make sure that the long end of pipe is under water by about 2 inches. It is VERY IMPORTANT that the end that goes underwater (The INLET) is hooked to your pick-up attachment.... You should have labeled it INLET already.
The whole idea is that whatever your vacuum sucks up gets pulled underwater first, trapping it before it gets near the vacuum cleaner. It has worked for decades for oil burner service techs to keep furnace soot out of their vacuums, which would be destroyed after one or two uses otherwise.This will easily trap dog hair and talcum powder. Be forewarned that inside the bucket it will get very messy and it is vital that you clean it after every use.
Good Luck!
Mar 20, 2011 | VAX Appliances 2000 Canister Vacuum
The hose is disconnected, new bag in unit, new filter, unit runs when hose is detached but immediately turns off when hose is attached but hose has no obstruction, etc.. i was told i need some sort of...
There is a vacuum hose that attaches inside the unit to a round clear plactic piece. In most cases you can simply cut the small vacuum hose and it will fix the problem.
Apr 16, 2009 | Electrolux Epic 3500 Vacuum
Reset light is on.
set big Cat to stay on porch. (Smile)
Dec 07, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele Cat & Dog Vacuum
doubt it. could be dangerous to use. (had one burn up due to this)
Apr 23, 2007 | Miele Cat & Dog 326i Bagged Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
