Question about Watches
Restarting watch Model 6789
How do i set the correct hour on my Maxum watch?
Hi Willow, well it depends on your watch model. Here is a site where you can find the instructions for a number of Maxum watches. Just look at the rear of your watch to find the model number and then copy the site address below and past into your browser and hit enter/return. Within the list that appear in this site find and click the model number of your watch for the instructions to appear. Good luck!
http://www.maxum.com.au/watch-instructions
Jan 10, 2018 | The Watches
What is the proper battery for my Gucci Watch model 3000
Don't be cheap!!!! Go to a reputable jeweler. Most of them are very clued up on these watches and they will give you the correct information. There are many types of batteries and sizes of batteries. There are also a variety of movements for battery watches. If the wrong battery is put or forced into the watch you can do damage to the watch and then will become more expensive to fix!!!
Mar 28, 2013 | Gucci Watches
Restarting a Casio 4735 after battery change
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
this video is only an example as to what to do hope this helps you..
http://www.youtube.com/watch?v=ogCz2vjUKVg
Jul 26, 2012 | Casio AW Watches
My Diesel watch (DZ-2039) has stopped. How do I start it? I know you're meant to shake it for 40 secs or something but it still won't start... any tips?
There is no such a thing as watch shaking for restarting it. Your watch need professional watchmakers help and for that you have to visit your nearest watch repair shop.
Jul 31, 2010 | Diesel DZ2039 (Size: ) Watch for Men
Kennet Cole Mens Watch Model A126-08 KC1494 How to adjust time
I have a Kennet Cole Mens Watch Model A126-05 KC1296 and I'd liked to know
How to adjust time
Jan 16, 2010 | Kenneth Cole Watches
A question was asked and answered about a casio 1170 last september from repman. I have the same problem with restarting the watch. Ihave tried grounding what looks like 'AC'inside the watch with the +...
The best Solution for this Problem as of Now is :-
1) Take off white plastic cover so that the only metal cover is seen
2) Notice in upper right corner there is a "golden" pad - tiny one and in the metal cover there is an engraving AC. Use some needle like (conducting) object and connect this pin to metal cover (ground) - this will reset your watch.
I am not sure, whether you tried the same thing as you did mention AC .
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 22, 2009 | Watches
Replace strap Cousteau Explorations watch
Can not find a resource to repair broken watch band. I do not have model number. I only know the dial says exploration. There are no model numbers on the watch case.
Feb 24, 2008 | Cousteau C059 Wrist Watch
Restarting my Citizen Promaster Eco Divers 200 Watch
Since it's eco-drive you can just wear it for a few hours and it should self-wind. The problem is that when it sits still for more than a few days it winds down. It gets its power from the natural movement of your wrist as you walk around.
Once it starts ticking again you'll just have to set the time correctly.
Dec 18, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Restarting after battery change
My watch stops and when i try to wide it again it won't restart. I also do not have a battery in my watch. Please help!
Nov 04, 2007 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
