Question about Bunn Coffee Makers & Espresso Machines
I can't remove the sprayhead on my Bunn one-cup coffee maker. It won't budge! What can I do to loosen it for cleaning?
    Habit-Forming:
  • 28 Answers
You should be able to run a solution of vinegar and water thru the machine to clean the insides. About one half cup of white vinegar and four cups of water should do the job. After you have done this, run a couple of cycles of clean water (full pot of water) thru the unit to remove any loose residue or remaining vinegar.
Posted on Dec 13, 2016
Testimonial: "This works very well, Randy, but the sprayhead is still tight. Nonetheless, I have a clean pot and the flow is better even without cleaning the sprayhead. I'm going to try pliers as Ray suggested. Thank you."
    Top Expert:
  • Bunn Master
  • 51,186 Answers
Gently use pliers on it .
  • Kay Cook
    Kay Cook Dec 14, 2016
    Thanks, Ray. I'm going to try this and will let you know.
Why won't the sprayhead come off of the coffee maker
They stick after a while, with dried coffee, all I can suggest is to soak part in Very hot water for a while to see if it loosens up.
Feb 06, 2016 | Bunn Coffee Makers & Espresso Machines
SAYS COFFE READY PUSH LARGE CUP AND A COUPLE OF DROPS COME OUT THAN SAYS FILL AND PUSH STEAM HAVE DONE AND REDONE SEVERAL TIMES STILL NOT GETTING A CUP OF COFFEE TOOK TANK OUT AND CHECKED FOR FLOTATION IT...
Hello.
1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
Thanks.
Sep 18, 2011 | Jura Capresso Impressa S90 Espresso...
Using same amount of coffee i have been using for past three years,coffee is now being too weak to drink.I have a bunn 10 cup maker.
The first thing to check is to see if you have lost your sprayhead. The sprayhead is located underneath the filter basket. If the sprayhead is there, then it is possible the water is not hot enough. Pour water into your machine, and as it comes into the decanter, measure the temperature. It should measure between 175-185 degrees. If it isn't, then there is a defect with the heater. Please call us at 800-352-2866 with your model and date code once you have results.
Dec 26, 2010 | Bunn 10 Cup Home Coffee Brewer
The water is coming out of our BUNN very slowly.What is the matter?
Your sprayhead and steel tube which connects to the sprayhead from the tank may have a lime build up. Simply remove the sprayhead and clean it with a wire brush and make sure the holes are clear of any lime or debris. In order to clean the tube which is what the sprayhead screws onto you will need a deliming spring. www.midstatebeverage.com
Nov 15, 2010 | Bunn (VPRBUNN) 12-Cup Coffee Maker
The water dont seem to brew all the coffee in the filter....parts of the coffee is still dry....i have cleaned the pot and spray head and empty the tank and refilled with water...my bunn is only 3 months...
It sounds like you are either missing a sprayhead or need the flow restrictor sprayhead. If you will call customer service at 800-352-2866 we will be happy to resolve this issue for you.
Sep 17, 2010 | Bunn 10 Cup Home Coffee Brewer
Our Bunn coffee maker has worked great for two years, but all of a sudden when we go to make coffee, the water pours out FAST and not the normal slow drip and the coffee is weak weak weak...we have cleaned...
It sounds like you are missing your sprayhead. If you will call Customer Service at 800-352-2866 with the model we will be able to send you out a new sprayhead.
Aug 18, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Lime in coffee pot
We recommend cleaning your machine with white vinegar for 2 hours and then using the metal deliming tool under where the sprayhead is located. IThen flush it out with 8-10 decanters of water. If this doesn't fix your problem, please call customer service at 800-352-2866 with the model and date code.
Jul 20, 2010 | Bunn 10 Cup Home Coffee Brewer
My brand new Bunn BX... despite following exact measuring for the perfect cup of coffee, and trying various stronger measurements, my coffee comes out tasting like water. When I look at the grounds after...
It sounds like you might be missing your sprayhead. If you remove the filter basket and look up above it, there should be a dome piece with 5 holes in it. If not, please call customer service with the model and date code and we can provide you with a new sprayhead.
Dec 25, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
When we make a pot of coffee, the water goes through to quickly and the coffee looks like weak tea, how can we fix this, we only got the coffee maker about a month ago
This is usually caused by a missing sprayhead above your filter basket. take out the filter basket, and see if there is a sprayhead up there, or if there is just a little round pipe that the prayhead screws on to. If it is missing, you can contact your local Bunn dealer, or phone bunn directly, and they will take care of you. You can get a list of repair centers in your area at www.bunn.com
Nov 20, 2009 | Bunn 10 Cup Home Coffee Brewer
Unable to remove our sprayhead from our Bunn NHB Coffeemaker
You might try putting a butter knife underneath the sprayhead to remove it. If this doesn't work, then please contact customer service and request a tool that can be provided to remove the sprayhead.
May 14, 2009 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
512 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
