Question about Xantrex Technology Xantrex 806-1800 Xpower Prosine 1800 Inverter (806-1800) 800-Watt Power Supply
Where do I get a manual, or correct problem
I bought a Duracell Powersource 1800 and the second time I discharged the battery during the ''seasoning'' process the fault light came on and now I can't get it to go off or to charge. What do I do?
  • 66 Answers
New battery and only charge to 45%?
My new battery cam with an eight page manual containing instructions got use in a translated (poorly) version of the Chinese original. Of course I did not need a manual to install a new battery and ran into the same problem as you. Refer to the discarded manual and find one and a half pages on how to initialize a new battery.
OOPS JPG came out too small to read so here is a rough OCR
"User Manual on Laptop Battery
Respected users:
Thank you very much for trusting and using our laptop battery. Before using the battery, read this manual carefully. This instruction manual elaborates how to use and maintain the battery correctly. Batteries are consumables, and have a limited service life. However, we can prolong the life of the laptop battery considerably through correct operation, proper charging/discharging and correct storage.
Calibrate your laptop battery to optimize its performance
Inside the laptop battery is microprocessor software, which calculates the battery volume during the charging/discharging. Batteries must be calibrated from time to time to ensure correctness of the time and the percentage displayed on the screen. You must implement a complete cycle of charging and discharging the battery at the beginning of using the computer, and repeat this cycle every two or three months. The charging and discharging procedure is as follows:
1.Set the Power Supply option first: Right click on the screen and select Property -> Screen Saver -> Power Supply -> Power Use Scheme -> Portable. In all the subsequent operations such as When Computer and Use Battery, select Never. Under the Alert option, deselect Alert for deficient battery and Alert for serious battery shortage.
2.Disconnect the power adapter and use the battery until the computer is powered off due to exhaustion of the battery.
3.Connect the power adapter until the battery is charged to 100%. Before initial use of the computer (or resuming use of the computer after long-term storage), the battery must be charged to full.and discharged for 3-4 times to optimize the performance. The charging process takes more than five hours.
Note: When your battery is calibrated and reaches the best performance, set the Power Supply Options on your computer to the default value to ensure that the computer can send correct alerts to you, for example, low battery alert, and alert before the computer enters the hibernation status.
You must discharge the battery to let the computer power off, and then charge the battery to 100% to calibrate it. Then you can connect or disconnect the power supply anytime regardless of the status of the battery volume. Moreover, you can perform a deep charging and discharging cycle under control of the protection circuit in a time"
Sep 12, 2013 | HP Computers & Internet
Need DC car adapter for Duracell powersource mobile 100
the positive pin is the one to the right when looking at the power connector with the mobile 100 standing up correctly, the negative is the one at the far left. I made mine start charging this way: Still don't know what the middle pin is for. Just make your own cable out of an old car plug and possiblly a pc power source connector. it's not that difficult.
Apr 20, 2013 | Xantrex Technology Duracell Powersource...
Duracell charger wont charge..
The blinking indicator is telling you that the batteries have been inserted incorrectly. Otherwise, the charger probably no longer works
Jan 20, 2013 | Duracell AAA NiMH Battery Charger with 4...
No battery detected
LOL, good ole Vista. I would never discharge my battery once I got it charged. I know the instructions say that, but I just never do it. Sounds like your battery is defective. Send it back.
Apr 08, 2012 | Computers & Internet
I don't know if my unit is charging.I have plugged it in for over 16 hours and it still flashes chg.
If it is new, you might need to open up the battery compartment and make sure there is not a removable protective covering on the battery leads. Otherwise it may be a defective battery. Many times the manufacturer will warranty it if you call them.
Mar 04, 2011 | Xantrex Technology xPower PowerSource 1800...
Kodak digital camera not charging/ indicator not shown while plug in charger
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
Jun 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
The watch will show incorrect time within hours of
Usually this is a faulty battery - make sure you go to a reputable jeweller and have the battery changed. Even somewhere like Kmart will only use decent quality batteries.
I bought batteries off eBay once that were very cheap, and I had this problem all the time. Now I only buy Energizer, Duracell, etc.
Nov 25, 2009 | Freestyle Watches
0.798x4+1.798x3+2.798x2+3.798x+4.798=?
Get your calculator out.
A. 4 X .798 =?
B.1.798 X 3 = ?
C.2.798 X 2 = ?
D.3.798 X 4.798 = ?
Now add that all together.
[I read 3.798 times -> a Positive 4.798
What about you?
It's a Positive number, not a Negative one]
Sep 02, 2009 | Xantrex Technology xPower PowerSource 1800...
Xantrex Technology Xantrex 806-1800 Xpower Prosine 1800 Inverter (806-1800) 800-Watt Power Supply Logo
215 people viewed this question
Top Xantrex Technology Computers & Internet Experts
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
