Question about Ecoquest Air Purifiers
How to fix Buttons for Fresh Air by EcoQuest - Ecoquest Air Purifiers
  • 31 Answers
SOURCE: ecoquest fresh air repair
Regardless of unit the purifier plates may need replacement. How are the plates cleaned? Could it be that there is a residue from the cleaning agent present after cleaning? With new plates there is a little oil on the plates to prevent oxidation when in storage or transit. A little rubbing alcohol would do the trick.
Make sure the plates are dry before putting them back into the unit.
If the plates are seated right and clean you should see a faint purple glow on the plates when the unit is on purify.
Let me know if that's the case.
Posted on Feb 07, 2009
  • 80 Answers
SOURCE: Fresh air 2.0: Unit cycles on and off.
The problem is dust or moisture on one or more of the circuit boards, in the bottom of the unit. The problem is usually caused by resetting the cleaning reminder without actually cleaning the machine. ;-) It hasn't been difficult for me to solve so far. Remove the filter. Remove the two screws that hold on the plate where the rear switch is located. The wires are long enough that they don't need to be removed from the switch. Use a blow dryer or dry compressed air to blow off the circuit boards. ****Keep your face out of the way!!! Be sure not to get the blow dryer too close or too hot. If you have a Warm setting, use that. Good luck!
Posted on Apr 04, 2009
SOURCE: Need manual
Posted on Jul 31, 2010
  • 670 Answers
SOURCE: how to replace your uv light in your fresh air
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Posted on Dec 06, 2010
  • 1607 Answers
SOURCE: Fresh Air Model 2.0 by Ecoquest ultraviolet light
Do you have any error code like "Replace RCI Cell"?
Posted on Jul 19, 2011
Replaced rci and fan motor and my fresh air by ecoquest will not turn on. the digital screen lights up briefly but it is blank and then cuts off
I'm thinking it's the circuit board. I would call Vollara (they bought Ecoquest) & see if you can get a circuit board or send back to them to fix. 800-989-2299. Or, you can Google circuit board for Fresh Air & see if there are any suppliers that you can get it from.
Feb 22, 2014 | Ecoquest Fresh Air Air Purifier
Will contact cleaner "fix" stuck buttons?
How long have you owned the machine? Do you still have three year warranty? I wouldn't recommend spraying anything into machine. It will only damage the electronics. It may need to be fixed. Does the remote control still work?
Jun 27, 2011 | Ecoquest Fresh Air Air Purifier
My ecoquest fresh air turned off suddenly... when i turn it on again there is no power it keeps flashing in the front screen .. is it an easy fix or hard fix ? please advice ... thank you
Oct 11, 2010 | Ecoquest Fresh Air Air Purifier
Unit blinks as if it wants to start put will not start fan starts moving and than stops repeately. Front panel buttons do not work some of remote buttons do
I would check the wiring connections to the fan and to the display board. Make sure they are seated properly. If that does not fix it, then call your dealer or the company and see what options you have. The company number is 800 989 2299.
Aug 31, 2010 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier turning itself off and on rapidly
There is a problem with the main circuit board. Ecoquest will replace the circuit board. If the Fresh Air is still under warranty you have to pay shipping. If it is not under warranty, you'll have to pay all of the repair cost. You'll need to call to get an RMA number before you send it in, either way.
Dec 07, 2009 | Ecoquest Fresh Air Air Purifier
Why do you have to replace the plates in Ecoquest Fresh Air Unit
They get filled with the **** in the air which they remove for you.
Apr 16, 2009 | Ecoquest Fresh Air Air Purifier
Remote & buttons want work
HURRY - you are still within your warranty period. Call EcoQuest for support.
Jan 30, 2008 | Ecoquest Fresh Air Air Purifier
Air Purifiers Logo
154 people viewed this question
Top Ecoquest Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
