Question about Coffee Makers & Espresso Machines
Talea giro red exclamation light flashing fast
I have gone through the venting/priming procedure at least 20 times. After 3 attempts the descaling and grounds drawer lights lid alternating. I switch off the machine for 30s and repeat. The water flow is good when I do the priming and I've clean the brewing group. I've been doing this all the day and the red light still flashes fast. I also did a descaling cycle, and tested all the subsystems in the test mode and they all seem to work, I can get a good amount of water going through the dispensing head. UPDATE: I found the problem! I've been doing research online and I saw someone with similar problem and it was the flow-meter. So I dismantle the machine to get to the flow-meter. I cleaned it with a compressed air can and put all back together. It worked!!! then I assemble it and didn't have any extra screws ;-)
4 Suggested Answers
  • 55 Answers
SOURCE: Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Posted on Dec 18, 2009
  • 81 Answers
SOURCE: The alarm light to empty the coffe grounds drawer
Hi, the problem with your machine is with the grinder motor (not working).As soon as you press the coffee the CPU senses the motor is out of circuit and the lights start flashing alternately.
You can test it by doing this. Press and hold the steam button and switch on the machine, you will see the lights going around in anticlockwise direction. Release the button then turn the dial to left (Min) and press the steam button the grinder should work. The dial on the right (Max) the brew group will come up..and half way it will come back to normal position. Press the coffee button in that position will work the pump. Servicecenter can fix this if the machine is less than 2 year old FOC.
Posted on Oct 11, 2010
  • 92 Answers
SOURCE: My descaling and coffee grounds drawer light were
Make sure the brew group is in
rest position; the two references
must match.(look at the marks/arrows on the side of the brew group)
Make sure the components are in
the correct position.
The hook shown must be in the
correct position; to check its
position, firmly press the "PUSH"
Posted on Jan 14, 2011
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
Talea giro descale already done but red led of descale has not gone
I was told by tech that if you hold the water button in for a few seconds then this resets. It depends on what kind of water you use too. If you use filtered or spring water then you don't need to descale it as often and you can override this by above method. Hope that helps.
Aug 28, 2012 | Saeco Talea Giro Espresso Machine
How to descale machine talea giro plus
Many times if you perform once more descale the problem can be solved so here is a video that can help to repeat the descale
Aug 28, 2012 | Saeco Odea Giro Plus Coffee Maker
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
My Saeco Talea Giro plus is not even one month old and the descaling light was on. We have descaled twice thinking we did something wrong and the descaling light will not go off. During descaling the...
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
Mar 29, 2011 | Saeco Talea Giro Espresso Machine
Saeco Talea Giro Plus, descaling following instructions step by step. In step 12 the descaling light did not turn off. The warning light came on as indicated. In step 15, pressing the descaling button...
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Mar 26, 2011 | Saeco Talea Giro Espresso Machine
Talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
Jan 16, 2010 | Saeco Talea Giro Espresso Machine
Dec 10, 2009 | Saeco Talea Giro Espresso Machine
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
