Question about Mitsubishi WD-65638 65" DLP HDTV
Mitsubishi wd 65638- replaced lamp tv has a very clear picture, great audio, but picture is in black & white colors only
Slinteriors
  • 8617 Answers
SOURCE: tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Posted on Jun 10, 2009
localwonder
  • 6784 Answers
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Posted on Sep 02, 2009
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
  • 917 Answers
SOURCE: bright white spots on mitsubishi wd-73833 I just
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Posted on Mar 24, 2011
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi Televison & Video
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
Mitsubishi dlp wd-65638 with error code 61. What is this error code? How do I fix? no picture or audio.
if the power LED is flashing green then there is a circuit or board that either has a blown fuse or relay. if it comes on solid red when you turn on the television then the Lamp inside is burned out and needs replaced. Before you spend all the money that changing the bulb would cost i would invest that money in a good LED Smart TV instead. Sometimes you just gotta let that old technology go away.
Dec 30, 2014 | Mitsubishi WD-65638 65-Inch 3D-Ready DLP...
I have a mitsubishi wd 65638 . it powers up just fine then about an hour or so in it starts to slutter the colors then settles into a weird silver and grey colors setting like black and white but not
this sounds ilke the board maybe tring to go bad although i know it doe have colored bulbs but it has to be the circuit board this is what control the power distabution
Apr 09, 2014 | Mitsubishi WD-65638 65" DLP HDTV
Mitsubishi wd-65638 dlp tv error codes sound no picture replaced the bulb I get a code of 6 blinking red and 1 blinking yellow
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help.
Blinking codes to Mitsubishi PTVs are given in detail.
Apr 10, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Audio is working, no picture
you have either a defcetive signal pwb, FMT pwb or light engine. Does the menus appear clear when you press menu?
May 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-65638 65" DLP HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
