Question about Hardware & Accessories
FMP timer 151 8800 is just flashing P1 and none of the buttons are working. How do I reset the timer?
3 Suggested Answers
  • 33 Answers
SOURCE: Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Posted on Jan 24, 2009
  • 117 Answers
SOURCE: p1 error message, dehumidifier runs continuously.
coils frozen up?
check sears direct.com for manual
Posted on Jan 05, 2010
Fmp rimer 151-7500 how to change volume of beeper
There does not appear to be a way to adjust the volume of the timer.
Oct 06, 2013 | Franklin Machine Products FMP 151-7500 7...
Review ge 15312 settings
Copy following link to identify timer, download manual and link to detailed wiring diagrams.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
This timer has too many buttons, and programming steps are seriously layered. I think they were trying add programming options, and to avoid confusion found with other brands dawn-dusk timer programming, by adding confusing options and issuing a manual with tiny print.
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
Look on page 1 of manual on right side, just above 'random security options' heading: Manual says you can use + - buttons to scroll through programs.
OR: Press set-up button twice and P1 ON will display: Display should also display selected setting.
Press set-up again to see P1 OFF, etc
OR: Press set-up twice, and press Enter once.
Press auto button to exit programming, and current time should display.
Nov 13, 2012 | GE Hardware & Accessories
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
http://waterheatertimer.org/ST01C-program.html
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Even with new battery, on-off will not click
1) If timer worked before and stopped working, then manual says last step is to reset timer.
If timer will not function after reset, then timer is broken.
2) You posted under battery-operated ST01C timer, that comes with 1 year limited warranty.
Open following page to identify timer, read ez instructions, and download on-line manual
3) How to reset ST01C
Hold down on-off button and press reset button
Release reset button.
Keep holding down on-off button until INIT flashes on screen.
Release on-off and 12:00 will flash
Re-program timer using ez steps shown on link above.
Add a comment for more free help.
Mar 13, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Hi i lost the instructions and don't know how to set the clock. please give me step by step once i reset the unit.
You posed under Aube T-1032 7-day programmable.
Aube makes a list of timers and each timer has different instructions.
For your convenience, I posted the Aube timers and manuals :
http://waterheatertimer.org/Aube-timers.html
I answer questions for free.
I am more than happy to write out the long list of instructions from the manual.
But the instructions apply only to the T1032.
They don't apply to the T-1034, T-1035, T-1052, T-1054, T-1070, T-1073.
If you would like me to write out instructions for one of the other timers, add a comment and tell me which timer.
T-1032 Manual
Set current time on T-1032:
Press and hold reset button
Display should be visible
Press Hour button to set current hour with AM or PM
Press MIN button to set current minutes
Press DAY button until current day shows (for example TU for Tuesday)
Close cover and press cover to confirm times
Programming overview:
Make a chart of your programs before starting to avoid conflicts in programming.
You can set 7 different programs
Program1 program2 program3 through program7
Each program has ON and OFF
First you set program1 ON with times and days of operation
And then you set program1 OFF with times and days of operation
Programming:
a) program1 ON
Press PGM button until the display appears as below:
P1 ON means you are ready to set program1 ON
Press the Day button to select days of operation for program1 ON
Press Hour to set hour am or pm for program1 ON
Press MIN to set minute for program1 ON
b) program1 OFF
Press PGM button until display shows: P1 OFF
The display will also show the the same Days you selected for program1 ON
Press Hour to set hour am or pm for program1 OFF
Press MIN to set minute for program1 OFF
c) To set program2, press PGM button until P2 ON displays
Repeat steps above to set all 7 programs.
d) To finish programming, close cover and push in cover
e) Select operating Mode.
Press and hold the cover until AUTO displays.
f) Press in cover for manual override.
Nov 10, 2010 | Honeywell Aube by TI0323W5U 7Day...
We have a p1 code?
p1 is in the testing mode the hour button will click p1 p2 and p3 depending on how many times you click the hour button or minute button . This is to manually test the burner on low , medium, or high p1 being low.To put it in this mode hold the minute and hr buttons down at the same time for 3 seconds.I unplugged the unit to reset.
Dec 20, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a flashing P1 and the unit will not turn on
P1 usually refers to evaporator pan full with water. If you drain it out it will work fine. If you need to reset it just unplug the power cord for two minutes.
Sep 26, 2009 | Danby DPAC8020 Air Conditioner
Timer button blinks but doesn't turn on
There are several faults that can cause this. Shorted diodes in the high voltage, a bad flyback transformer, a shorted CRT driver IC. None of them are very easy to fix.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
