The blue light indicating that the reciever is powered up will not shut off,it stays on even after I unplugged it and plugged it back in
SOURCE: Onkyo HT-R501 7.1 reciever issues
you have to get it fixed. same thing happened to my onkyo reciever and they said it was a bad circuit. had to take it to an onkyo tech and have it replaced.
Posted on Oct 15, 2008
Fujitsu
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
petraman7
  • 1175 Answers
SOURCE: yamaha rx-v461 not working
Does the reciever have separate speaker switches?
Try turning off the speakers and turning on the amp.
If it doesnt have speaker switches , make sure ALL the speakers are connected at both ends and try turning on the amp again.
Posted on Feb 04, 2009
  • 61 Answers
SOURCE: blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Posted on Aug 28, 2009
budmrtn
  • 11361 Answers
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Posted on Oct 24, 2009
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
REPLACED POWER BOARD TV TURNS ON DISPLAYS PHILIPS AND SHUTS OFF ,BUT LIGHT BLUE INDICATOR LIGHT STAYS ON
If no signal (whatever the reason) most sets with a solid blue screen will shortly shut off.
A few things to try first:
Unplug set, a box if used, a receiver if you have it in line---wait a while and plug each back and wait to see if they reboot and restore signal.
Also look to see if you can get the set to a video input before it shuts off---A DVD etc should be connected and on when you try that.
May 26, 2012 | Philips 40PFL3705D 40 in LCD TV
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
Wii console not working correctly
When you connect to the internet wirelessly and Wii Connect24 your Wii will stay connected and recieve messages, updates, etc. That is why the disk area stays blue and the amber light stays on. Sometimes this will create a power failure. Just unplug your Wii from the wall and let it rest for a few minutes and plug it back in. The problem should be solved.
Feb 22, 2010 | Nintendo Wii Console
Lg 50 in clicks but won't stay on.
Ur power board need it replaced,LED indicator light not sustaning power.
Jan 05, 2010 | LG 50PC1DR 50 in. Plasma HDTV
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Acer laptop shut of during power outage .
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
