Return does not go back to left margin - Office Equipment & Supplies
  • 3594 Answers
SOURCE: IBM Wheelwriter 5 (Setting the Margin back to 5"
Sounds like you don't know how to set l. margin or you have some debris in the typewriter. Turn it off and see if the carrier will move back and forth by hand, if so turn it on 7 return to l. margin press mar rel key, backspace to where you want the margin and press l. margin key.
hope this helps
DickyO
Posted on Jan 17, 2008
SOURCE: Swintec 7000 typewriter
Lo and behold, some light oil on the stainless bars solved the problem.
Posted on Apr 08, 2008
SOURCE: reset left margin
Turn machine ON and return to what is set as the left margin. then press the MAR REL key (upper left side) one time and then press the BACKSPACE the number of times to get where you want to set the left margin.
Once you are at the desired position for the LEFT MAR then press LEFT MAR ONE time and it should be set OK.
Hope this solves your problem, sneaky pete
Posted on Jun 24, 2008
  • 3594 Answers
SOURCE: MARGINS
Try a little light oil on the silver shaft that the carrier slides on, if that doesn't do it then the carrier motor needs lubed, it is under the case on the R. rear corner.
DickyO
Posted on Apr 13, 2009
  • 8404 Answers
SOURCE: IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Posted on Oct 14, 2009
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
The return is stuck on 80 on the guide. I cannot
Turn the T/W off and slide the carrier back and forth. If it goes to the left then you have the L. margin set at 80.
Return to the margin, press and release the margin release key, backspace to the desired location, press the L. margin key.
DickyO
Mar 18, 2010 | Nakajima AE-710 Typewriter
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
Dec 29, 2009 | Swintec 7040 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
I am using an AE-830 and have the left margin stuck in the middle of the page. How do I release and set back to the left? Thanks
Move the printer to the margin using return button. Press the margin release button, backspace to where you want the margin to be, then press the left margin set. All should be good.
Oct 13, 2009 | Nakajima AE-830 Typewriter
Setting left margin. For some reason, I've set a new left margin, and can't get back to the old, more left margin.
Return to L. margin, press mar. rel. key backspace to desired location press L. mar. key.
DickyO
Aug 17, 2009 | IBM Office Equipment & Supplies
Reset left margin
Jun 12, 2008 | Olympia Mastertype 3 Typewriter
hope this helps
DickyO
Jan 15, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
k24674
