Question about Electrolux Vacuums
I need to know where and how many filters are on my Electrolux Harmony Canister Vaccum and how to change them?
The Electrolux Harmony Canister Vaccum has filters. I need to know where they are located on the machine and how to change them?
4 Suggested Answers
LizDahl
  • 75 Answers
SOURCE: Harmony power head parts
I work for Aerus Electrolux, my office #570-326-1731 if you call with the model #s and etc I can find out what you will need. Liz
Posted on Feb 23, 2008
  • 52 Answers
SOURCE: electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Posted on Nov 14, 2008
SOURCE: Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Posted on Apr 17, 2010
Ultraactive vaccum filter keeps popping off
There are two possible causes for this issue. The most likely is that your exhaust filter is blocked and so the air literally cant get out. You need to replace the exhaust Hepa Filter every six months anyway so get a new one and see if that fixes the problem. If it still is popping off after this it means the tiny lugs on the filter cover are damaged so you will need to get a new one of those.
Jul 11, 2013 | Electrolux UltraActive Turbo Bagless...
Model of BAg?
HI Your Exlectorlux uses Electrolux Style OX bags. Here's a few links back to our website to several different style of bags that will fit your Electrolux:
Genuine Electrolux Vacuum Cleaner Bags for Harmony Canisters
Generic Electrolux Style OX Vacuum Cleaner Bags for Harmony canisters
Hopefully this helped you! Please be sure to rate my repair helpful, or leave feedback if this was able to answer your questions.
Thanks,
Chris Jones
GoVacuum.com
May 02, 2010 | Electrolux Harmony Canister Vacuum -...
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Harmony Not working
maybe it is clogged. does the light go out if you turn it on with no bag?(for testing)
is the roller spinning?
Jan 07, 2010 | Electrolux Harmony Canister Vacuum -...
The light on the top of the vaccum stays light and
You have a Electrolux, not a Guardian though, right? The light you are talking about is the bag full indicator. I know your bag is not full, so, try this. The knob on the top of the cleaner is a fine adjustment designed to let the bag fill up in different conditions, (dirt types) . So...turn the dial down to setting 2. Try it again. Did it work? If so, this is your adjustment . No need to ever adjust it agin. It is NOT the suction control. If this did not fix ya (haha) then, your adjustment diaphragm is bad and you will have to break down and bring it to Aerus(Electrolux) for a repair. I hope this info was helpful, if so, please leave feedback, it helps my rating, Thanks, Rene(The Vacuum Doctor)
Nov 07, 2009 | Electrolux Guardian Bagged Canister Vacuum
Where can I gett a replacement filter collar for Electrolux Harmony , model EL6985?
HI. I can assist you. Any electrolux dealer can get the part you need. To locate a local dealer go to this link:
http://smallappliances.electroluxusa.com/node85.asp
Aug 01, 2009 | Electrolux Harmony Canister Vacuum -...
Can't get dustbag to fit
The dust bag doesnt fit into hose your supposed to out ur bag into the plastic bag holkder then sit inside the canister and this model does not take an ox bag it takes an s bag y
Apr 10, 2009 | Electrolux Harmony Canister Vacuum -...
Electrolux canister vaccum 2100
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Cover won't close
Try removing the bag and closing the cover. Unless that piece that holds the bag has gotten loose, there isn't anything that should prevent that cover from shutting, so it may just be the way the bag is sitting.
May 03, 2008 | Electrolux Harmony Canister Vacuum -...
Feb 23, 2008 | Electrolux Harmony Canister Vacuum -...
Vacuums Logo
26 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
