Question about Dishwashers
F1 code showing and rotors will not stop spinning
I have to unplug dishwasher to stop the rotors from spinning
  • Tim Holman
    Tim Holman Jan 12, 2017
    i have the same problem have you had any answers
2 Suggested Answers
SOURCE: Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Posted on Apr 21, 2009
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
I have a f1 come up and a f2 on my dishwasher what is it
f1 = Flood Code
This means that the dishwasher most likely has a leak
There is a float switch in the bottom of the machine and when water gets down there it trips the code
F2 = Roter not moving
you can remove the basket and spray arm and pull the roter out and make sure its clean and give it a try.
Jan 21, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Need to get out old motor rotor assy so we can put new one in.
This video will wok you through your Fisher Paykel repair, how to fizz a f1 error code and how to replace the rotor.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Sep 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error code continuosly
here is a link to a downloadable repair video. This video explains how to repair a f1 error code and how to replace the rotor.
Mar 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher is not draining during washing cycle. Water is always sitting at bottom of dishwasher pan. Also, when the draining cycle is going on the dishwasher (?) pump made a strange sound (not smooth...
Locked rotor on the bottom of the machine. If you remove the bottom plate of the dishwasher where the water valve and electrical hook up is the motor is right there. If the rotor on the motor is locked up the dishwasher will not drain.. If you take a screwdriver and spin the rotor on the back of the motor it may release the rotor. If it does not spin freely then you will need to replace it. Make sure to unplug the dishwasher before doing any repairs to it.
Hope this helped you some
Dave
Jan 12, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
