Question about Vizio Televison & Video
My Vizio E-470 - a0 has a problem with screen grayish line across top and bottom off screen
    Top Expert:
  • Vizio Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Dec 13, 2016
aminic
  • 61 Answers
SOURCE: Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Posted on Sep 20, 2008
SOURCE: Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Posted on Dec 15, 2009
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
SOURCE: flickering white line across top of vizio 47
I had that problem on my Vizio 37" and my new Vizio 55" and now after reading the solution of adjusting the HV position in the setup menu, the problem is fixed! Thank you!!
Posted on Jan 01, 2011
SOURCE: I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Posted on Jul 24, 2012
The bottom of the image on my Vizio E500d-a0 is distorted. It goes from blurry to really blurry every 2 seconds. This happens even with all devices unplugged with the TV menu up. Is there a fix?
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | Vizio E500D-A0 50" LED Smart TV 1920x1080,...
I have a Vizio model E-470 - a 0 it has a grayish line across top and bottom of screen can still see TV fine accept looks like a filter grayish any ideas
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 11, 2017 | Vizio Televison & Video
Vizio e420i-a0 picture problem. Vertical lines that progressively get brighter and sometimes the proper image displays but it is split vertically in 2 or 3 sections.
May 09, 2016 | Vizio E420I-A0 42" LED TV 1920x1080, 120...
Vizio E420I-A0 Black Screen
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Vizio E470i A0 Blank Screen No Backlights How to Test Power Supply...
Testing TV Backlight LEDs
Testing tv backlight leds EsBuzz net
http://www.badcaps.net/forum/showthread.php?t=41334
Mar 10, 2016 | Vizio E420I-A0 42" LED TV 1920x1080, 120...
I have a vizio 470-a0 that is dark and the back light blinks every 5 seconds
The front LED light that shows whether the TV is on or off will flash so many ... press and hold the power button for 5 seconds upon plugging the TV in. ... The flashing code I got meant the power supply was bad.
Feb 08, 2016 | VIZIO, INC. E470-A0 47" 1080p LED-LCD TV -...
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
I have a Vizio E320I-A0 and it has multiple vertical and horizontal lines on the screen, how do i fix that?
Probably the T con board is faulty. T con board is the one which drives the lcd pixels. Chekc the video to identify the t con board. Also try to remove the connection to T con board and reconnect it. some times bad contact on those connectors can lead to such problems.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
Sep 22, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
