Question about Crafts & Hobbies
Lionel transformer type 1044. I am replacing the whistle switch shaft. How do I secure the retainer sleeve to the shaft?
3 Suggested Answers
residentoccu
  • 161 Answers
SOURCE: lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Posted on Feb 15, 2013
SOURCE: I have a lionel type KW Trainmaster Transformer
New wire and plugs are available at chuckstrains.com , they can also tell you how to get into it
Posted on May 10, 2013
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
The whistle on either side of my 1966 lionel zw transformer does not work
The contacts on the switch may be dirty but the most likely problem is that both selenium rectifiers are dead. Replacement silicon rectifiers are available if you want to do the repair yourself. Check the internet for suppliers. You can get the ZW repaired at most good Lionel service centers for a reasonable price. Get a list of service centers by searching on-line or at Lionel.com.
Mar 05, 2014 | Crafts & Hobbies
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
Repair a lionel 1044 toy transformer
What is your question?
Dec 23, 2012 | Toys
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Steering wheel changes
Here is the simple steps to change the old steering wheel and install the new one.
Remove the Original Steering Wheel
1.Read instructions that come with the steering wheel, and gather the following tools: screwdriver, pliers and a puller.
2.Point wheels straight ahead.
3.Disconnect battery or pull horn fuse before removing the old wheel. This prevents the horn from shorting out or blowing during installation.
4.Remove the horn mechanism by doing one or more of the following steps: Press down on the horn cap or ring and turn; remove the emblem cap from its snapped-in position by grabbing it and pulling it toward you or prying it loose; or if the horn ring is secured by screws that are concealed in the rear side of the wheel spokes, use a screwdriver to remove the screws and the ring.
5.Remove horn wire or spring-loaded metal plunger from plastic housing by either pulling straight out on the metal plunger or, on most models, by twisting the plastic sleeve to the left and then pulling out. Cut the wire off the plastic sleeve and keep the sleeve for later use.
6.Remove the shaft-nut retainer clip, if it is present, and keep for later use. Remove the shaft nut, which holds the wheel to the shaft.
7.Mark the shaft at the twelve o'clock position so that you will know where to position the top of the new wheel.
8.Insert a conventional puller into the two tapped holes which appear in the hub of the old wheel and pull off the steering shaft.
9.Remove the original wheel.
Installing the New Steering Wheel
1.Place the small tubular metal sleeve down over the steering shaft.
2.Position hub on splined shaft, making certain that the shaft is properly positioned using the mark you made in step 7. You may have to rotate the plastic horn contact tube slightly to align it with the appropriate hole through the hub.
3.Insert plastic sleeve and spring from step 5 without wire into plastic horn housing. If the plastic sleeve extends above the top bolt surface of the custom hub, cut down the sleeve so that it is 1/8-inch below the top of the hub. Remove sleeve.
4.Insert through the plastic sleeve the wire lead that was supplied in the wheel kit. One end will not pass through the sleeve. This bell-shaped end will go into the horn contact housing. Insert the sleeve and wire into the housing and lock into position.
5.Route wire around the hub from the ten o'clock position to about the two o'clock position to properly align wheel. Position post cover and wheel on hub. Make certain that the wire lead passes through the appropriate holes in the two o'clock position. Using the three shoulder bolts provided, fasten the hub, post cover and wheel together, but do not tighten.
6.Check wheel for proper positioning. If correct, reinstall the shaft nut from step 6 and tighten. Reinstall shaft-nut retainer clip. If the retainer does not fit into the groove on the shaft, tighten the nut until it will fit as originally located.
7.Remove shoulder bolts and reinstall them through the retainer ring with the fiber side toward you. Tighten the shoulder bolts with caution - excess torque will result in damage to the hub. The shaft nut, if correctly tightened, will firmly hold the hub and wheel assembly on the shaft.
8.Connect wire lead to the connector on the retainer ring. Position spring on center nut. Align the dimples of the horn cap with reliefs in fiber material and push into the dimples past the fiber. Turn cap left or right until tight.
9.Reconnect battery or replace fuse.
Sep 09, 2010 | 1991 Honda Accord
WHISTLE STOPPED WORKING on CW-80
replace the button with a new one just remember which wire goes to which terminal. you will need a soldering iron and electronic solder to do this trick , also make sure you un plug the transformer. by any chance you got any n-scale trains you want to get rid of . If you do send me the info @ robert.e.kelsey.jr@gmail.com I'am a disabled veteran with little funds.
Nov 30, 2008 | Lionel Cw 80 Transformer
My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Nov 18, 2008 | Lionel Cw 80 Transformer
Crafts & Hobbies Logo
120 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
