I have a TURBO AIR MSR 23 G-1 It is constantly going to a freezing 28 degrees, can not get it to stop freezing. Is there a trouble shoot for this dilemma?
peyton32034
  • 410 Answers
SOURCE: Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Posted on Jan 21, 2009
  • 121 Answers
SOURCE: self closing doors don't self close any more
This problem can be corrected by adjusting the hinges.
Posted on May 09, 2009
  • 11 Answers
SOURCE: air conditioner
Clean your coils off and change your air filter. Should correct the problem rather quickly unless you have a refrigerant leak.
Posted on Aug 24, 2009
  • 1531 Answers
SOURCE: refrigerator 1/2 temp will not get warmer than 28 degrees
try and replace the thermastat control.
turn both knobs to the off position and listen i the fridge for the cold air damper to close it is located top left side rear of the cabinet in the fridge if the door does not close then you may need to replace the damper
Posted on Apr 13, 2010
SOURCE: my ridgleline stopped blowing cold air from one
replace the hepa filter located behind the gove box.
Posted on Jun 01, 2010
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
It is hellishly hot outside these days, something close to 40. I bought a 6000 Haier at Best Buy and wanted it to lower room temperature to 25 Celsius. Vain hope: working non-stop day and night at high...
This window unit cant keep up in temps above 100 degrees farenheit its not going to happen. 28 degrees celcius is all your going to get in that heat Im in St. louis MO and its the same way
116 degrees farenheit heat index
Jul 21, 2011 | Haier HWR08XC7 Air Conditioner
Freezer not freezing - can hear a clicking noise coming from areond the th.ermostat / motor area
My freezer has a light that says "high temp" but the freezer isn't freezing my products.....what can I do? It also says that the temp has been 23 degrees or higher for more than 1 hour. I really don't think that the problem is being in hot weather
Apr 22, 2011 | Freezers
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Self closing doors don't self close any more
May 09, 2009 | Turbo Air MSR-49NM Refrigerator Commercial
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
