Question about Kyocera Office Equipment & Supplies
  • 98 Answers
SOURCE: Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Posted on Aug 23, 2007
  • 208 Answers
SOURCE: Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
SOURCE: paper jam
We had this same problem. You need the back cardboard section of a legal pad. Take out the cartridge and slide the back of the cardboard slowly into the rollers, pushing it out the end where the paper comes out. This helps push the paper jam out. You may have to do this several times slowly to get the jammed paper out. But it worked for us!
Posted on May 21, 2008
  • 741 Answers
SOURCE: Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
Posted on Jun 02, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
Kyocera paper jam duplexer
The duplexer unit is located at the bottom of the printer. You have to remove the paper cassette first. Second, tilt the printer a little on the back side. In place of paper cassette, you will see an iron plate with a green handle in the left. Push down on the handle and the plate will go down. You may find paper jam there or pice of paper stucked. Release the handle and put back the printer and paper cassete, then open top cover and close it down. You may have paper jammed also under developer unit, or in the fuser section. Verify there, if the first solution won't solve the problem.
Apr 07, 2014 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Open the left cover and inspect the paper tray and the fuser unit.90% paper jam in the fuser/exit unit.Inspect and clean the rollers and the fingers.
Oct 02, 2009 | Canon imageCLASS MF6590 Copier
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
Apr 07, 2009 | HP LaserJet 4 plus Printer
Paper jam at output on the Imagerunner 1310
I have a solution. Take a baseball bat and knock the crud out of that ******! That will fix the problem of not having a door! Thus it will make a verrrrrry easy opening to get the paper out! :-D
Feb 04, 2009 | Canon imageRUNNER 1310 Printer
Kyocera C5015N paper jam can't remove
I guess it is stuck in the Fuser at the back, concertinaed at the exit claws,
Remove paper tray complete, pull green handle right side where paper tray came out, another tray will stop 3/4 of way out, there is a tab on each side, that you press in, one on each side of the rail, these are the bits stopping tray from coming out all the way, once you have the "process tray" removed you can see in to the fuser entry side and they may be enough to grab and remove it. If not unplug, top and sides off, unplug 2 cables, remove fuser screws and remove fuser.
Dec 17, 2008 | Kyocera FS-C5015N Laser Printer
Paper Jam
If you are getting a lot of jams in the fuser then there is a problem in the fuser unit !
Is it jamming like an accordion? if Yes, then the problem is w/ the little fingers in the fuser, they are worn and need to be replaced. The rollers in the fuser should be shiny and smooth if not they ca also cause jams.
What black thingy are we talking about and where? if it's the fuser rollers ( where the paper exits and gets hot then try cleaning w/reg soap & water rag then wipe off.
Nov 17, 2008 | Sharp AR-153E Copier
sounds like a fuser jam. remove top and side covers, then rear exit tray. remove fuser screws and connectors. should be able to remove paper with fuser out of machine.
Oct 08, 2008 | Kyocera Office Equipment & Supplies
51 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
