Question about Dometic Heating & Cooling
I need a wiring diagram for the thermostat to the air conditioner
Mouse chewed through phone type wire connected to the dometic thermostat. Spliced out the breakage but the thermostat still doesn't work
  • 1,929 Answers
Typically red is power green is fan yellow is cool white is heat. Those four should make it work if it has batteries.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 13, 2016
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
motor1258
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
shastalaker7
  • 1515 Answers
SOURCE: I need Hitachi RUA-30AT3S wiring diagram. This is
FSM Forums • View topic - Hitachi Air Conditioner ManualsHitachi Air Conditioner Manuals - looking for Operations & Maintenance Manuals, ... RUA 30AT3S (Package 30 Tons) RUA10AT3S (Package 10 tons) ...
www.manual-directory.com/forum/viewtopic.php?f=10&t=2453...0 Hi, although your unit is a 2 1/2 ton, you will be able to get a manual showing you the correct wiring diagram using the model number you supplied. It shows your model above. This is the only way to get a diagram for this unit. Please keep me posted on the out come or if you need more help.
Sincerely,
Shastalaker7
Posted on Apr 03, 2010
  • 415 Answers
SOURCE: looking for wiring diagram for a duo therm by
There are several models out there. Here are a couple of manuals with wiring diagrams that I believe will help you regardless of the model number. However, if they are unable to help you, let me know the exact model number and we'll search for the wiring diagram. :-)
Link #1
Link #2
Posted on May 19, 2010
Thermostat wiring diagram for Domestic RV rooftop AC
go on internet look up troubleshooting dometic rv a/c's
Feb 13, 2015 | Dometic Rooftop RV Air Conditioner
New digital therm. air works but no furnace can be found on therm.
What make and model of AC, as well as Make, model of thermostat ? Need that info for proper diagram.
Sep 13, 2012 | Dometic Rooftop RV Air Conditioner
I am trying to wire a 3107546.008 thermostat but only have 4 wires yellow,red,black,and green
most thermostats for a split system strait cool has four wires,now the heat pumps come with more wires.i'm not for sure what you are talking about.please explain.
Dec 18, 2011 | Dometic Rooftop RV Air Conditioner
My AC unit had been blowing warm air for a couple of days so i went outside to take a look and noticed that the dog had chewed through the thermostat wire so I spliced a new wire in. Since then, the AC...
When you spliced the wires you shorted out the low voltage side of the system..
Now the fuse blew on the circuit board of the furnace or air handler if you are lucky enough to have a fuse in there...
If there is no fuse then the transformer is blown and will need to be replaced...
heatman101
Aug 11, 2011 | Heating & Cooling
Wiring
Maybe try calling Grainger or they might have a website online. Have you googled the brand of your thermostat? Often PDFs pop up with manuals.
Jul 14, 2010 | Dometic Rooftop RV Air Conditioner
I have no voltage to my thermostat
Possible transformer problem or a broken wire between the thermostat and the a/c
You will need an electric meter to check for voltage at the transformer One side should be the power feed and the opposite side should feed the 24 volts, or 12 volts depending on type of unit.
I suspect that there is a break in the thermostat wire to the unit. You can test this by getting enough wire for the thermostat and go to the board on the roof top unit where the thermostat wire connect and connect the wires that you have to the existing board i.e. red to red green to green and so on. once you have connected these wires to the proper screws then take a new thermostat and connect the wires to the new thermostat and activate this should tell you if there is a break in the wiring or possible transformer problem but as I said I think its a break in the wiring
Dave
Mar 19, 2010 | Dometic Rooftop RV Air Conditioner
AC unit fan won't turn
Yes those are the Thermostat Wires to the Unit Reconnect and you should be Fine.
Thanks
Please Rate me
George
Apr 26, 2009 | Dometic Rooftop RV Air Conditioner
Wires not connected on mod# 6759c707
If you google Coleman rooftop air conditioners on your computer, it will give you some dealers that sell that air conditioner and they should be able to help you or tell you where you can get the help.
Apr 03, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
