Question about Dishwashers
The rotor will not stop turning on the dishwasher
I have a Fisher Paykel 605 double DD. I have an F2 error message. There was a frozen rotor, likely from disuse over the winter. I replaced the rotor and it still stops and shows the F2 display. There
Not sure if you have fixed the F2 problem yet. The rotor cavity may look clean but sometimes there is a piece of bone or seed stuck inside the channel connecting rotor cavity with pump sump. Take the rotor out and the drain filter out. Take a rigid thin wire and run it inside the channel connecting the two.
Also get some white vinegar and with a tooth brush rub it inside the rotor cavity to ensure all dirt is removed. The rotor speed sensing is done by the hall sensor sitting underneath the cavity. It is not visible from top. The sensor could be reading incorrectly. IF still no luck then Run in diagnostic mode - (but make sure you do not try any other function than what is mentioned here otherwise you could damage dishwasher).
DishDrawer Diagnostics can
only be entered in Power Off mode, ie. When there is no display on the LCD or the
badge LED's are off. Diagnostics is entered by holding the
Keylock and Start/Pause buttons simultaneously for 5
seconds. Ensure that
Keylock is pushed first.
All LED's and LCD segments (except keylock) are illuminated. Press Power button and display shows HO in red background. Press Start/ Pause. You are now in hardware diagnostic mode. Open drawer so that you can see inside. Press Start/ Pause a few times until FU shows on display. At this point press Keylock and water should flow in. Press Keylock to turn inlet valve off after water is collected under the wash arm (don't cover wash arm). Press Start/ Pause again and P1 will display. Press Keylock to turn rotor motor on and water will swish around. Press Keylock to turn motor off within a few seconds otherwise flooding could occur. Next press Start/ Pause once so P2 displays. Press Keylock to run rotor again but this time it will pump out. Let it run until the water is pumped out. Press Keylock to stop pump. This should test the rotor in both forward and reverse direction.
PRESS POWER BUTTON ANYTIME TO EXIT DIAGNOSTIC
If the hardware test worked ok then turn mains power to dishwasher off and on and start normal wash cycle. If there is still an F2 problem then hall sensor is faulty and needs replacement. Not easy to do and best left to technicians. By the way each dishdrawer has separate controller - so one drawer could be working fine and the other not.
May 10, 2014 | Fisher and Paykel Dishwashers
I have a DD603ss Fisher Paykel Dishwasher that will not complete it cycle and stops with a beeping sound and a faucet symbol on the display. The washer itself has hot water in it that will not drain. ...
Solution
This is telling you that you have a leak ,the sensor is in the bottom of the unit under the drawer, your best bet is to call for service. This unit has to be pulled out and disassembled unless you have some one that is very handy!!
Originally the dishwasher ran for a minute and came up with an F2 message. I removed the basket, blade, and blue component (not sure what it is called) I cleaned them and ensured that the all moved freely but have only placed the blue component back in. The unit progressed more into the cycle but has the above problem referenced above.
Solution
F2 means that your rotor is jammed. If you open the drawer and remove the dishrack, you can pull straight up to remove the wash arm. There is a plastic locking ring in the center of the silver filter plate. Twist this 1/4 turn counter-clockwise and pull the filter up and out. Next is the rotor, turn the rotor 1/4 turn counter-clockwise as well and replace this part because it's not functioning correctly (assuming you don't see something blocking the rotor from moving that you can just remove).
Below is the link to order the same :-
https://www.fisherpaykelparts.net/product/525884P/525884P-Motor-Rotor/
There is a probability that if all of these error message's are there, there is a problem with circuit board. A problem with them could cause multiple error message or displays on the screen, even though there is no such issues. So, this problem has to be collectively inspected and checked before you could order any parts.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 09, 2011 | Dishwashers
My fisher dd6031 bottom drawer doesn't seem to get rid of all the water,,and it keeps beeping and will keep beeping through the night if you don't catch it...we have been putting it through another rinse...
You will have to take the filter plate out the motor rotor out. Then clean the rotor cavity and replace in reverse order.
Are you getting any error codes?
Does the beeping stop if you turn the power off and on?
Sep 05, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
LE on the display panel
LE is a motor error.
Possible Causes: Wiring connections, Impeller is locked, Rotor is locked, and or the Blade is locked.
Remedy: Repair the wiring issue, Remove the item stopping the turning of the motor/rotor/blade, Replace the sump assembly, or Replace the main Power Control Board.
If your motor was making in knocking sound before this error, then your issue is probably the motor sump assembly. Just replace the sump assembly and your problem is resolved. You can get these from EBAY for about $105 with free shipping.
Good luck.
Jul 23, 2010 | LG LDF6810ST Stainless Steel Built-in...
Displays LE and will not wash dishes
Good luck.
Jul 18, 2010 | LG 24" Built-In Dishwasher - Black
I have a old Asko Dishwasher. It works perfectly. However at times at the end of the wash cycle the soap remains in the dispenser. This happens half the time.
Put less soap in. Your wash will be fine with less soap. We have same problem. MARK: do not have tall objects underneath that will stop upper rotor from spinning. Also objects in upper basket kan penetrate and stop uppper rotor from spinning. Using less soap works for us.
Mar 09, 2010 | Asko 24 in. D3450 Dishwasher
What is fault code f2 on fisher & paykel dishwasher
Rotor is not moving. Remove the spray arm, filters and the rotor, check for debris. Rotor impeller should turn if you try to turn it manually. If it does not - replace the rotor. Here is your part: http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
Nov 26, 2009 | Dishwashers
Glasses and dishes coming out unclean and smeary have put a cleaner in but no difference part where salt goes in keeps filling up with water
Make sure that there is no blockage of the water flow to rotors (i.e. a pot located over a central water spout, misaligned movable water connections).
Next, make sure there is no cutlery or the like that goes through the slide out baskets to stop the rotors from turning.
Also, just give the rotors a spin by hand to make sure they are free to do their job.
Have never heard of a salt being put anywhere in a dishwasher - just in a water softener which is usually not part of a dishwasher.
Oct 17, 2009 | Indesit Dishwashers
Whirlpool Quiet Partner 2 dishwasher
You need to clean the 2 rotors properly and that also includes the sieve. Make sure once the dishes are stacked, the rotors must turn freely by hand.
Sep 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
