Question about Canon PIXMA Office Equipment & Supplies
My MG3100 is printing over its self how do I stop it from doing this
Lost start up disc Canon MG3100
Dear you can download the DRIVERs and SCAN software from the canon site. Also the link may helpful.
PIXMA Printer Software or MG3100 series MP Driver Ver 1 02 Windows 8 1 8 1 x64 8 8 x64 7 7 x64 Vista...
Thanks.
Feb 26, 2015 | Canon Office Equipment & Supplies
What IS ERROR E 2 ON THE PIXMA MG3100 PRINTER MEAN?
Hi, you will find some info here!!>> https://www.youtube.com/watch?v=rJQVwwRxPv4
Oct 18, 2014 | Office Equipment & Supplies
Canon mg3100 printer is printing blurry
Could be paper quality problem, moisture on paper or the most likely is you need to clean the ink port.
Jul 31, 2014 | Canon Office Equipment & Supplies
INK RESET IN CANON PIXMA MG3100
First off..Law has it that Printer Manufactures can not restrict their machines from using cartridges from other vendors. So you can purchase less expensive carts from the likes of www.inkjets.com. Why bother refilling when they are so cheap and the carts are actually new. Carts with print-heads built in are tested and work great. When line appear, the print head is plugged up. You may simply have a cartridge with ink that fits into a separate Print Head and locks into place. If so, that Print head is no good. It should be replaced, or run under very hot water for 10 minutes, both sides, until no ink is visible. Dry on a soft towel and do not touch the metal parts. Replace and do a printer test. That's it.
Feb 08, 2018 | Canon PIXMA Office Equipment & Supplies
Canon pixma mg3100
check to see if the ink cartridge is in properley
Jan 28, 2014 | Office Equipment & Supplies
In epson lq1150 /II esc/P2 how to clear data in memory. Already removed alldata in print Que .Restarted System as well as printer.
Actually, what you're doing already clean up the data in memory.
If the memory still contain data, maybe there's something wrong with the printer.
Run a self test print whether the printer is okay or not,
Turn on the printer while holding down the LF/FF button or Load/Eject button. If it start print, that mean the printer okay. Press 'Pause' and turn OFF the printer and then turn On back to stop the self test printing.
Jul 04, 2012 | Epson Office Equipment & Supplies
Print from iphone 4s
hi Francesco Mauri.. try follow this link , hope can solve your problem . http://itunes.apple.com/us/app/canon-easy-photoprint/id331269951?mt=8
importants:: printer must to be connect via wireless first , then the iphone will scan and detect.
Apr 01, 2012 | Canon Office Equipment & Supplies
I am getting 4 big thick black lines about an inch thick on top of my printed page, how can i stop this ?
Try printing a test page to see if your ink levels are normal. Then instruct your printer to do a self cleaning, where it will clean the print heads.
Mar 07, 2011 | Brother Office Equipment & Supplies
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
23 people viewed this question
old marine
old marine
