Porfavor los codigos de tv marca Hezz - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
Posted on Dec 13, 2016
Manual control remoto huayu rm-36e+
disculpen la pregunta pero alguien me podria decir cual es el codigo para televisor de marca global poorfa escriban el codigo y no me den los link porq no enkuentro nada ..!!! porfavor
Jan 10, 2012 | Universal Remote Control Remote Control
Necesito codigo de tv daewo para control dish
Mi nombre es Kimberly Escobar trabajo con DISH Network servicio al cliente. Entiendo que necesita programar el control de DISH Network con su televisor Daewoo, seria un placer asisterle proveendole la informacion que necesita. Para programar el control con su T.V existen ciertos codigos que se integran al control en base a la marca de la television. Por ejemplo para la marca Daewoo unos de los codigos serian 531, 719, 727, y 654. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba hasta que los demas botones se prendan, luego ingrese uno de los codigos por ejemplo el 531 despues de ingresar el numero va a ingresar el signo de numero (#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar el control deberia de funcionar. Si tiene preguntas adicionales porfavor contacteme directamente a kimberly.escobar@dishnetwork.com o tambien puede visitar nuestro website http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos e informacion adicional. Gracias espero esto le sea de ayuda.
Oct 24, 2011 | DISH Network IR Remote Control
CODIGOS PARA TV GE
HOLA TENGO UN CONTROL REMOTO UNIVERSAL STEREN RM 11 Y MI TELEVISOR ES GENERAL ELECTRIC ALGUIEN SABE QUE CODIGO ES
Mar 08, 2011 | DISH Network IR Remote Control
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
PROGRAMAR PLATO CON CONTROL MAGNAVOX Televisor
Mi nombre es Kimberly Escobar trabajo con DISH Network servicio al cliente. Entiendo que necesita programar el control de DISH Network con su televisor Magnavox, seria un placer asisterle proveendole la informacion que necesita. Para programar el control con su T.V existen ciertos codigos que se integran al control en base a la marca de la television. Por ejemplo para la marca Magnavox unos de los codigos serian 566, 564, 887, y 546. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba hasta que los demas botones se prendan, luego ingrese uno de los codigos por ejemplo el 566 despues de ingresar el numero va a ingresar el signo de numero (#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar el control deberia de funcionar. Si tiene preguntas adicionales porfavor contactenos directamente o tambien puede visitar nuestro website http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos e informacion adicional. Gracias espero esto le sea de ayuda.
Aug 24, 2010 | DISH Network IR Remote Control
Codigos para televisor LG Haier y Coby
hola mi nombre es henrys hernandez pero necesito los codigos para un tv plasma coby sin mas gracias mi correo es henrys.hernandez7@gmail.com
Jul 28, 2010 | EverFocus RE100H Remote Control
El codigo del control remoto de una tv mitsui
el control remoto del digitalizador motorola no trae codigo de acceso a la tv mitsui, cual sería el código de acceso; hablé a Megacable y no tienen registrada la marca de la tv así que no pudieron darme el codigo de acceso y me recomendaron que indaagara en internet
Dec 19, 2009 | Televison & Video
Perdi el manual de mi control remoto universal GE RM 24912
que remoto? va a la website de el remoto und mira por los codigos ahi
Jun 11, 2009 | Emerson EWF2703 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
