Question about Microwave Ovens
I have a WFG720HOAS Range that the oven will not stay on. The gas igniter lights fine and it is about a 50/50 shot weather it will pre heat to the set 350.
If it does make it to 350, it seldom will stay at 350 the entire time for cooking. Some days it will stay at 350 fine, others when you have guest for dinner it decides to go out.
  • Microwave Ovens Master
  • 9,771 Answers
I'd have a look at the thermostat. It controls the operation of the igniter. and the gas valve.
Posted on Dec 14, 2016
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
Automatic burner lighter is not working on my gas range, Amana The Big Oven
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 26, 2011 | Amana Microwave Ovens
Frigidaire Gallery stovetop model number LGEF3031KMB Oven will not heat up to temperature. Oven, Pre-heat lights will come on, but the oven will not reach any temperature set.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 11, 2011 | Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Maytag MGR5730BDW gas range oven do not bake, the automatic pilot turn on but burner bake don't start
heatman101
Jul 04, 2011 | Microwave Ovens
The oven is gas - the top burners light, but the oven doesn't heat and appears to not be getting gas.
heatman101
Jun 25, 2011 | Microwave Ovens
20" gas stove: has pilot light in oven, oven lights but then after several minutes will turn off. do not smell gas after it turns itself off. Using 3/8" gas line. Please advise as to potential problems...
The oven igniter should stay on constantly as long as oven control is calling for heat and not fade off. If the igniter is too weak and not pulling enough current it may not open the gas valve correctly and gas will be let out of the gas valve and not igniter.
The likely failure is a weak oven glow bar igniter. I recommend calling a service technician to diagnose and repair your range.
Hope this helps .
Apr 21, 2010 | Microwave Ovens
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
