Question about Alcatel Cell Phones
Alcatel 3G (cheap and old phone) In the upper left hand corner it is showing a "V" and when I dial out it goes to beep, beep and no ring?
SOURCE: Speed Dial quit working
why for restart my V3 mobail?
Posted on Feb 22, 2008
SOURCE: 3G symbol
It means that you are receiving a 3G signal (which means your phone can send and recive information at a much quicker rate- for internet or video call for example), it has nothing to do with any buttons you have pressed. It could also display an E or an H in the same position on your display.....depending on your network or ......
I could go into it more.......but i'll keep it brief. you get the idea!
Posted on Sep 01, 2008
SOURCE: 3G Symbol
According to the manual this symbol means "HSDPA network connected"
Posted on Sep 30, 2008
Joshi_Z
  • 567 Answers
SOURCE: red triangle on left hand top corner - K800i
hi
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
Posted on May 25, 2009
micromaster
  • 3614 Answers
SOURCE: how to deactivate call barring?
Go to Settings >>> Network services → Call barring. Clear all the call barrings that you have set.
Hope this helps
Posted on Dec 02, 2009
HOW DO I EDIT MY CONTACS ON ALCATEL FIERCE
Go to the contact then in the upper right-hand
Corner and there will be an icon tap it and choose edit contact
Feb 24, 2015 | Alcatel Cell Phones
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
Apr 08, 2013 | XO Vision Xtab Android Ebook Reader
Can i stop the alcatel one touch 665 from playing a tone when i open and close the clamshell
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Nov 20, 2011 | Cell Phones
My iphone has my last name wrong on caller ID
Your iPhone uses the name that is listed in your address book for called ID. On your iPhone, go to Contacts, click on the name of the contact you wish to edit, hit Edit in the upper right-hand corner, and then change the last name accordingly. Once you are done, hit Done on the upper right-hand corner again, and now the correct name will show on caller ID.
Jan 28, 2011 | Apple iPhone 3G
What does the H symbol on the top upper left corner of the phone screen mean? How come it keeps switching between an H and a 3G symbol?
probably the state of the internet connection H could be HSDPA and 3G obvoiusly 3G. Which phone?
Nov 25, 2010 | Cell Phones
I have a toshiba dkt2010-sd how go i program this phone ... right now my display screen has NO.11 in the upper right hand corner and lower left corner it has CALL 11-15
What do you want to program? to get rid of blinking light press intercom and dial #409 to program display name type Intercom #620 and #621
Jan 21, 2010 | Toshiba DKT2010SD Phone
Purchasing Ringtones for iPhone 3G
Once you have the application downloaded to your computer, you have to sync it to your phone.
Plug your phone into itunes, when it shows up on the left hand side underneath devices. select the iphone there. This will bring you to your summary tab.
In the middle near the top you will see different tabs including Summary, info, ringtones, music, etc...
Go to your applications tab. If all of your applications do not show up in that list, go to file in the upper left hand corner and click "transfer purchases from iphone".
If all of your applications appear in that tab. Put a check mark next to sync applications and select all applications.
Click apply in the lower left hand corner and this will sync the application to your iphone. Access the application to download the ringtones.
Sep 29, 2009 | Cell Phones
Itues Says it Cant read SIM
you need an AT&T '3G' sim card to restore the phone then you can put the old sim back in.
im sure that will do it.
Aug 18, 2009 | Apple iPhone 3G Black Smartphone
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Cell Phones Logo
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
