Question about Garden
I need a wiring diagram for the safety interlock system on a Dixie chopper 2760kw mower
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
SOURCE: can you point me to the wiring diagram for the above mower
The flywheel black (negative) and red (positive) wires are the magneto output. Red goes to ignition to charge the battery, and also burn the headlights -- so the red will go to the headlight switch as well, maybe through the ignition.
There should be an in-line fuse on the charging/headlight wire coming from the magneto.
There should be a safety switch under the seat which energizes the fuel cutoff solenoid on the bottom of the carburetor.
There are also interlock switches on blade engage mechanism, and the brake pedal, These prevent engine from starting if brake is not applied or if blades are engaged -- these would control current to the ignition module.
This is not complete, but it'll give you some clues -- good luck -- it's a ton of work.
Posted on May 08, 2009
mickey813
  • 472 Answers
SOURCE: Ariens Riding Mower Model #927025. Safety
you cant you need to get it to a shop to get that fixed
Posted on Oct 01, 2009
  • 7 Answers
SOURCE: oil leak around the oil filter
the oil filter is either cross theaded or the filter is not tite enough
Posted on Jun 27, 2010
Dixie chopper won’t turn over, but the slam sounds when key is turned on
you will get all info on wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally
this website www.reliable-store.com
it's a very good site for all vehicles even my car 1991 model.
Mar 19, 2018 | Cars & Trucks
My Dixie chopper classic 2750 won't crank it turns on but it won't turn over it just makes the beeping noise. What's the problem?
Wrong site. I tend to fix mowers, but they have to be with me. 2 or 3 a year compared to 300 cars I do a year.
Aug 20, 2016 | Cars & Trucks
How to move a dixie chopper if the mower will not run
Without the model number I was able to look-up exactly where the following located but if it hydrostatic model then will be release levers for the drive wheel transmissions. Note it will not completely free wheel on hydros but will make moving possible.
Oct 15, 2014 | Garden
How to change engine deck belt on a 2006 Dixie chopper mower
there isn't such a thing... it's either a hydro (motion) belt or the deck drive belt. Dixie's also sometimes had 2 belts for the deck... the drive belt and the blade belt. your model number should be under the seat
Sep 13, 2014 | Garden
How to get a dixie chopper repair manual
Don't seem to find a 27060 classic. The only classic available is a 2760 or 2760T or 2760W.
Best to go to this Dixie Chopper support site and select the model carefully. You may not find a service manual but depending on what you may want to repair, the parts manual may be sufficient.
Manuals Dixie Chopper
Aug 19, 2014 | Garden
How to change drive belt on Dixie chopper silver eagle lawn mower
THERE SHOULD BE A BELT ROUTING DIAGRAM UNDER A MOWER FOOTREST SOMEWHERE, OR CONSULT MANUAL OR DEALER
Jul 28, 2012 | Garden
I cannot locate the battery in our Dixie Chopper Xcaliber 3300. I've looked under the seat and elsewhere. Help please!
Mine is under deck in front.Lift the foot deck away from seat to flip to front of mower.There you will find battery.
May 28, 2012 | Garden
Where is the battery located on the dixie chopper silver eagle
The location of the battery depends on the particular model of the Dixie Chopper Silver Eagle line. All 50" and 60" Silver Eagle machines have the battery located under the seat. All 34" and 44" Silver Eagle machines have the battery located directly under the muffler and main frame between the support brackets in the battery case.
Feb 15, 2011 | Garden
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
