Toshiba SD-V55HT won't turn on, zero power and YES, its plugged in
    Top Expert:
  • Audio Player... Master
  • 21,456 Answers
Replace the start up capacitor in the switch mode power supply if you are competent to do this as there is 400Volts DC on it!
Posted on Dec 12, 2016
Why do I get disc err when I insert a dvd?
Most likely dirt on the lens of the player. It will need cleaning.
Apr 05, 2016 | Toshiba SD-V55HT DVD/VHS Home Theater...
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
My toshiba DVD/VHS combi won't turn on and yes it
The power supply regulator section, or main ON/Off switch should be checked.
Jun 05, 2012 | Toshiba Televison & Video
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
I wanna buy some speakers wires for this system i cant find them anywhere7067676412 if you have them
Even if you can find them they'll probably cost a relative fortune.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Toshiba-SD-V55HT-Home-Theater-Systems-manual/id/284ag007/t/2/
Page 13 shows the wiring scheme.
The wire itself is just glorified lamp cord. Go down to Radio Shack or the hardware store and buy 100 feet of 18-gauge lamp cord and make your own - cheap.
Maybe bring the unit down to an electronic store and see if they have any compatible ends to match the proprietary outputs.
There are a couple whole non-working SD-V55's on eBay for under $60 delivered. If you check with the sellers to make sure the have the cables maybe you can work a deal.
http://cgi.ebay.com/4K33-TOSHIBA-SD-V55HT-HOME-THEATER-DVD-WORKS-FM-WORKS-/140508685542?pt=LH_DefaultDomain_0&hash=item20b6f864e6
http://cgi.ebay.com/Toshiba-SD-V55HT-Home-Theater-Receiver-DVD-VCR-PARTS-/160492805226?pt=Home_Theater_in_a_Box&hash=item255e1ddc6a
From what I've seen asked for proprietary cable sets, these would be bargains.
Feb 19, 2011 | Toshiba SD-V55HT System
49 people viewed this question
 Grubhead
Grubhead
