Question about Garden
I have a Western plow. My controler lights when plugged in, the on button works but when I try to use the plow the controler shuts off.
autotherapis
  • 501 Answers
SOURCE: hi, I have a 2000 dodge ram and when i plug my
There is a ground that is deteriorated in the harness. trace the ground lead back from the connection to your truck. Once you find the break, that should take care of your problem.
It is also possible to be a power lead, so check them also, but more often than not it is a ground.l
Hope this helps.
Posted on Dec 14, 2009
  • 57 Answers
SOURCE: I have bought a minute mount 3 plug plow. The
It sounds like there is an in-line circuit breaker which is either defective, or not big enough or the motor is drawing too much amperage. Check with the manufacturer and ask the questions: what size circuit breaker should be used and what is the minimum wire size required. Check against what you actually have. You will probably find a wire hooked directly to the battery and the circuit breaker is usually located first in line close to the battery. Too small wire size could cause a fire.
Posted on Sep 22, 2010
  • 90 Answers
SOURCE: I have a 03 silverado
run a power wire directly to the positive side of the battery, make sure you install a fuseable link
Posted on Dec 13, 2010
  • 31 Answers
SOURCE: my 2008 f-250 looses the
test to see if the lows share the same circuit. it is also possible the bulbs are bad, or an error in the wiring.
Posted on Feb 01, 2011
  • 3368 Answers
SOURCE: How do I fix the plow pump it wont turn off?
I do not know that unit but it sounds like either a leak internal to the hydrulics or a bad pressure switch.
Posted on Dec 14, 2014
Off/on light is flashing on HT handheld control and nothing is working on fisher plow but the headlights
joystick controller is saying its not connected to plow valves or pump , this happens a lot due to plug corrosion , using a squirt or two of "electric contact cleaner" in both sides of plugs helps with this
Jan 19, 2016 | Fisher Minute Mount Plow Joystick...
Plow lights work OK, but why is there no power to joystick?
Bad connection in plug,bad wire, fuse or fusible link, faulty joystick.
press the helpful button and check link below
western plow problem Snow Plow Forum Let Talk Snow Discussion Forums
Jan 14, 2016 | 2002 Ford F-150
Western plows
Needs bleeding,got air in the line.
Dec 09, 2013 | Cars & Trucks
NO power wont lift
boss plow will not go up or down, do not have light on main control. Truck lights will go on but when toggle switch is activated, truck lights stay on and plow lights will not go on.
Jan 28, 2011 | 82" TruckSUV Snow Plow
Western snow plow when you try to angle to right it goes up does same thing if you try to angle left
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Oct 30, 2009 | Plumbing
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
