Question about Coffee Makers & Espresso Machines
Why are the green lights on each side of the machine flashing, also when the pod is inserted the lights flash and you need to press the lights to stop the water flowing
JohnnyBeans
  • 223 Answers
SOURCE: Flashing red water light and flashing green lights
You can download it at
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Saeco Parts and Information
www.cerinicoffee.com
Posted on Nov 19, 2007
SOURCE: Saeco Caffe Charisma lights do not stop flashing
I had the this same issue and made a post to this thread, in that post I had this solution to my conditions.
The combination of actions that seem to work was turning the Saeco on while the steam valve was already open and selecting hot water once the Saeco was powered on. The prime light went out, I closed the steam valve
Posted on Jul 20, 2008
  • 39 Answers
SOURCE: Krups XP2070 Stops putting water through after a
Most likely a faulty flow meter unit which is not providing the right information to the control unit. Replacing is not too difficult and the replacement meter is < $20.
Posted on Dec 29, 2009
  • 92 Answers
SOURCE: Tassimo Coffee Maker: Tell me
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
Posted on Jan 14, 2011
  • 4 Answers
SOURCE: Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Posted on Apr 17, 2011
How do we get the machine to start?
Hi,I dont know if this is eney help but I just bought a tassimo - coffee machine and it sounded just like you described yours,
I pluged it in,then I took the water container of the back where I found a yellow disc,(do not remove the bar code from the yellow disc other wise the machine wont work) I inserted the yellow disc where you put the t-pods,then fill water - container and put it back in place,then I switched the on switch on,it should show a yellowy orange light nexst to the silver button,then press and hold the button for 5 seconds and let go,the light will flash and turn green,then give it another 5 seconds then hold the silver button in again it should now despence hot water ,when water stops press the silver button again do this about 4 times,now your machine is ready to use,take the yellow disc out and put it back in the place you got it from,
now just put the t-disc you want to drink and have a rest.
I hope this was some help.
Feb 11, 2015 | Krups Coffee Makers & Espresso Machines
Why does My nespresso machine keeps on flashing 3 lights
Please see http://www.fixya.com/support/t14787831-nespresso_u_all_lights_flashing_pod for previous answer, or see troubleshooting at http://www.nespresso-us.com/media/product/PDF/38manual.pdf
Jul 06, 2014 | Nespresso Coffee Makers & Espresso...
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
Tassimo Coffee Maker: Tell me how to operate it. I can fill the water, put the pod in and all the lights keep flashing. Pressing the start/stop button does nothing.
and start over.
HOW TO MAKE A DRINK
the brew cycle.
Jan 14, 2011 | Braun Tassimo Espresso Machine/Coffee...
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Hang-up
Hi, when a apple i pod freezes and refuse to function, it means that the i pod memory has stop working due to an application you installed in the i pod.
To rectify this problem, you will need to flash the i pod for the memory to start working properly.
Flashing an i pod helps you restore lost memory. After flashing the i pod, you can now start using it again as normal.
Take care.
Apr 14, 2010 | Apple iPod nano 3rd Generation
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
Flashing green light on base unit BT Studio 3500
The flashing green light is the in use indicator on the base. Click the scroll button down on the handset to show the call list, then press the x or secrecy button, then press the tick or menu but to confirm, the call list is now empty and the green light has stopped flashing, You need to repeat this for each handset until complete
Oct 11, 2009 | Dual Lands Phones
Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Sep 18, 2009 | Nespresso C100B Essenza Single-Serve...
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
