Question about Saws
My radial 12-51 saw starts up then sometimes goes into reverse and/ or "hiccups"any advice appreciated
  • 3,111 Answers
Yes ma'am.
If you saw actually does go into reverse, you have a short in the windings of the motor.
It would be a really good idea to unplug it and plan to scrap it.
You have not said whether it is made in China or not.
If it was made in the USA, you might look at the manufacturer's sticker and try to contact that company over the internet on your computer.
If it was made overseas, likely you cannot get it fixed here.
It is very, very dangerous if it is doing as you say, because it can kick the material you are attempting to cut back at you and injure you severely.
God bless your efforts.
Posted on Dec 12, 2016
De Walt radial arm saw old model 7740. Am trying to restore it to working condition Very difficult to change the height adjustment due to binding when trying to turn the handle on the top.
The manual for the saw is included below, To free the height it may be best to remove the saw carriage from the arm to reduce the weight.
Use WD40 or equivalent to cut the rust and a suitable grease to maintain the freedom. There is a worm screw that is below the cylinder that may need lubricating. The manual shows the assembly. I routinely apply 90 weight gear oil around the large tube where it goes into the housing,
http://vintagemachinery.org/pubs/252/1213.pdf
26351737-byjyd4kzhh1rgh2pqslbdjkq-3-0.jpeg Hope this helps?
http://vintagemachinery.org/pubs/detail.aspx?id=1213
Nov 12, 2016 | Delta Radial Arm Saw
While ripping 1x4's my 10 inch craftmens saw stopped running. Pushing in on the reset button doesn't help. After 2-3 minites saw will start up again. I'm not forcing the boards and overwor
the thermal motor relay is shutting it down,,motor to hot,
insure that all the air vents or saw housing are not full of saw dust. blow it out with air from a reversed hose on a shop vac if you don't have a compressor.
hope this helps.
Jan 03, 2018 | Craftsman 10" Table Saw
Delta radial arm saw want start just hums
sounds like single phasing..is this a 3 phase saw..then one leg is down...if not, then it sounds like a start capacitor. Ensure the switches have been metered and are good.
Jan 01, 2012 | Delta Radial Arm Saw
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full...
most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Aug 02, 2010 | Dewalt DW744S 10" Portable Table Saw with...
I have a Delta Rockwell Radial Arm saw model L-40C (equivalent to model 33-527) that is running backwards. How do I reverse the motor rotation?
Sorry I don't know the saw in question, but I would assume either the starter winding connections or the run winding connections have been reversed. Was the motor replaced or was the starting capacitor serviced recently?
Thanks!
Jan 20, 2010 | Delta Saws
Radial saw motor just buzzes.
It sounds like the start circuit is shot on the motor of the radial saw. It is trying to start, (the buzzing sound), but the start is not is burnt out, and therefore the run winding is drawing excessive amperage trying to start the motor (a job it is not designed to do) and eventually builds a amp draw in excess of the circuit. You will have to determine which is cheaper a new motor, or a new saw.
Hope this helps
Sep 25, 2009 | Saws
Craftsman radial arm miter saw parts discontinued
Any hardware or home improvement store will have a replacement.
Jul 22, 2009 | Craftsman Saws
Saws Logo
71 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
