Question about Lincoln Welding Tools
I have a 250 Lincoln ranger. My welder will start and run but it will not strike an arc.
CarlGehrke
  • 169 Answers
SOURCE: lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
Posted on Feb 23, 2009
mamicheddy
  • 79 Answers
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
Posted on May 07, 2009
  • 4090 Answers
SOURCE: M lincoln 225 arc welder runsfan comes on but will
Transformer is burned out. Various windings are taken off at different points to alter the amount of power, they have eventually burned right through , So that is why some worked and some didn't It has now completely gone. The cost to replace the transformer may well exceed the cost of a new welder.
Please rate my help++++Thanks for using FIXYA
Posted on Jun 18, 2010
  • 518 Answers
SOURCE: my lincoln ranger 250 no weld output
sounds like the transformer winddings which generate the amperage for the arc are breaking down
Posted on Jul 07, 2010
  • 173 Answers
SOURCE: My Lincoln SA 200 welder will not rev up when I strike an arc.
check the solenoid make sure its opperating ..you will have to check the whole system.. starting with oil pressure switch making sure it is letting 12v go thrue. and also making sure pc board is grounded . and then checking resistance of the idle solenoid .....also the rhostat has a wire that goes to the pc board and as u strike a arc it idles the welder up
Posted on Sep 14, 2012
Why will it not rev up
Welder Idles but dosnt rev up so when i strike an Arc [Archive ...
www.hobartwelders.com > ... > EQUIPMENT TALK > Generator/Welders
Apr 21, 2008 - 7 posts - ‎4 authors
... is good there,I have continuity from the wire there back to the Auto Idle Module,and i... If it does not affect the idle. then check these things. ... out,,can i put a PTO cable on the throttle and pull up the RPMs when i weld? right ... Benefits of Stick?
Sep 26, 2007
SA 250 will not strike an arc
May 7, 2006
Lincoln Weld-Pak 100hd.. Need some opinions, =]
Jan 15, 2005
Aluminum repair
Mar 19, 2003
More results from www.hobartwelders.com
SA-200 Idler Troubleshooting - Weldmart Online
https://www.weldmart.com/main/.../sa200idler_troubleshooting.html
The solenoid pulls the carburetor throttle plate closed and the engine drops to idle ...Turn it off (close it) and the solenoid releases; the welder idles up. ... If it does show power-with the engine off, remove the wire and recheck the terminal. ... B. The idler solenoid is good but it will not idle up when you strike an arc, or when a ...
Idler control for sa 200 lincoln welder - American Welding Society
Dec 08, 2015 | Welding Tools
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
What is wrong with the idle on my welder? the switch works , it idles up when I switch it on high and it idles down when I switch it down but it wont go up when I strike an arc or use power tools, what...
There is something wrong with the auto load sensing switch which is part of the generator. That is the sensor that detects when current load from the generator drops as in when you strike an arc or turn on a power tool and cranks the throttle to full power. It is obviously working on manual because the manual switch is cranking the revs up so the solenoid that operates the throttle is ok. My advice is to take it to a service centre that deals in welder/generator sets as you are playing with dangerous voltages and may possibly damage the machine by tinkering with it or fry yourself (nasty)
Jun 27, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
It will strike an arc but has no power to burn a rod doesnt matter how small new or old rod is.only has 150 hrs on it
it sounds as though there is a fault with the rectifier. In which case you'd need to take it to a repair shop to get it repaired properly
May 29, 2011 | Lincoln Ranger 250 Gxt Welder Generator...
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My lincoln ranger 250 no weld output
Jul 03, 2010 | Lincoln Welding Tools
Welding in TIG mode. Weld for 10 minutes, stop
the unit will need to go in for service there is a control bord issue there 4 in the unit these boards have to be tested by Lincoln i have the same welder and what they will do is swap out the boards till the bad one found if the unit is not under warranty they can be expensive mine coast 500.00 for the 1 control board there is not a clear way to say it is a particular one do to there all inter linked as to functions. go to the web site and search for a service center in your area hope this helps
Jul 02, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
WHEN I TRY STRIKE AN ARC WITH A ROD YOU HAVE TO HIT IT 5 OR 6 TIMES TO GET IT TO WELD ITS HARD TO KEEP IT GOING BUT AFTER 4 OR 5 SECONDS IT WILL BURN LIKE NORMAL (USING PROPER AMPERAGE)
Is this on new rods as well as one's you'be been already welding with? Depending on rod types, some will "flux over" the end, after welding insulating the tip. When you're welding at a low setting, with a small rod, sometimes it is hard to start an arc. A 7018 rod is a good example of this. Strike the rod like a woodden match, or drag it on the metal, to expose the rod. It also depends on your welder. Some have settings to help start an arc and then control the current. Older transformer welders arn't that smart and are less forgiving on low current thin metal settings.
Jul 02, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Welding Tools Logo
139 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
