Question about Asko T701 Electric Dryer
T700 Asco dryer will not start
Hello, The dryer seemed to blow a fuse (popping noise when turned on, then silence, nothing moving). Is this something we can repair ourselves? Thanks. Rebecca
    President:
  • 1,776 Answers
It probably blew out the thermal fuse. The thermal fuse should be located just inside the rear of the dryer on or near the exhaust duct. The fuse is about one inch long. It is easily checked with an ohm meter or multimeter. It should have continuity and if it doesn't it's bad and will need replaced. Sure hope this helped.
Posted on Jul 20, 2009
Car wont start cant move shift out of park new battery and plugs
nothing happens means the starter is Silent?
yes silence happens. ?
after all nothing is zero , how can zero happen,??? LOL.
the operators guide covers this.
how to crank in neutral, read that yet.
you must have what.?
1: fuses good.
2: charged battery. is it, ???? 12.6vdc rested?
3: brake fuse and working brake lamps. are theY?
this is called park lock out feature.
id dont have liberty books. zero.
nothing happens when i look for this book, LOL
on older jeeps there was a magic bypass device, for emergencies, but the dam(n) gov , made that ILLEGAL, like most things now.
I get lost here
I cant shift to neutral, or can
and if can shift to neutral, does the starter make noise.
that, GGGRRRRRHHHHAAAAA sound....
makes the crank shaft turn. even seen to turn....you can...
Dec 27, 2015 | 2005 Jeep Liberty
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
Hello, I have a Kenmore Elite Dryer Model 110.65062500 that just clicked when I press the start button. I replaced the Thermal Fuse and the dryer started working again but after two loads, it looks...
you have to clean out the dryer.if the vent line is long blow it out with a leaf blower,remove the duct that the lint filter slides into and clean that out and vac out the cabinet where the motor is.if you don't do this the fuse will keep popping,the dryer can't move the air because lint is blocking the air flow,if the dryer starts to run to hot the fuse pops as a safety so you don't have a fire from not cleaning out the dryer
Feb 17, 2011 | Dryers
Asko T700 dryer won't run
Have you checked the 15amp fuses which are located at the back of your Asko dryer ?
That is where I`d start. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting fixya today and good luck.
macmarkus :)
Apr 08, 2010 | Asko T701 Electric Dryer
When I push the knob for the dryer to start. NOTHING HAPPENS.Dead silence.
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 04, 2009 | Maytag PYE2300AY Electric Dryer
Deyer wont start hear nothing but a hummm noise
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down. If all of this fails then yes its the motor
Sep 21, 2009 | Kenmore 62602 Electric Dryer
How do I get at the rollers in an Asco T700 electric dryer? Thanks Roger A
Loosen backplate, dismount the drum, then you will get acsess the rollers. some work, but you'll get there.
Jul 17, 2009 | Asko Dryers
Asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Oct 25, 2008 | Dryers
Sansui Amp
Bad supply capacitors...accordianman
Mar 09, 2008 | Audio Players & Recorders
Asko T701 Electric Dryer Logo
234 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
