Question about Zanussi Washing Machines
Zanussi jet system washer error code 247.whats this mean?
    Master:
  • Zanussi Master
  • 480 Answers
Nothing. It is not error code, maybe is time washing for example: 2 hours and 47 minutes. All errors code starts with letter "E" and two numbers or only with two numbers.
Dado
Posted on Mar 10, 2017
  • 10 Answers
SOURCE: zanussi jet system 1000
A E90 fault code means the main pcb board is faulty and i'm afraid to say, they are a expensive item and not always easy to replace, some come pre programmed and just swap across and others have to be programmed using the code on the white sticker on the board housing. either way it normally better to get a engineer to replace it because you don't get the programming instructions with the new pcb. I hope this helps
Posted on Jul 18, 2008
SOURCE: Zanussi
 The drain filter is clogged (E20)
online manual
http://www.serviceforce.co.uk/pdfs/U21039.pdf
Posted on Oct 31, 2008
  • 25 Answers
SOURCE: e10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Posted on Feb 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have an E20 error
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Nov 05, 2010
pjhislay1
  • 822 Answers
SOURCE: what does the error code E66 mean on a Zanussi
the heater element is faulty
Posted on Nov 02, 2013
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    My zanussi washer is coming up with error code 40 anyone no what it is
    Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
    Dado
    Aug 27, 2015 | Zanussi Washing Machines
    Jet stsem water hase stopd comming in the washer
    If you mean there is no water in jet system than I suggest to check circulation hose (dirty) of jet system and circulation pump otherwise problem is in " intake water".
    Dado
    Jun 14, 2015 | Zanussi Washing Machines
    I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
    This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
    Apr 26, 2010 | Zanussi IZ161S Front Load Washer
    E 20 ERROR ZANUSSI JET SYSTEM
    E20 is a general error code to get to the real problem try this..
    Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
    Sep 07, 2009 | Zanussi FJS1225W Front Load Washer
    E10 code on a zanussi jet system washer
    Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
    My Zanussi washer will not start and the end light flashes 9 times. Do you know whats this means
    This indicates error code E90. Sometimes its a loose connection to the front control board. But it would usually require a replacement one Zanussi call them a user interface hope this helps you.
    Dec 17, 2008 | Zanussi FJS1225W Front Load Washer
    Zanussi jet system 1000
    Jul 09, 2008 | Zanussi FJS1225W Front Load Washer
    Error code e60
    Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
    Jul 07, 2008 | Zanussi ZWF1440 Front Load Washer
    Zwd1471s washer dryer
    E20 code on Zanussi washer dryer ZWD1471
    washing machine working but dryer is not .
    Any advice please
    Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    Washing Machines Logo
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
