Question about Vacuums
Vacuum cleaner is not starting, and green light plug indicator is lit. I tried unlocking all connections and then re-locking them with no success. What am I not doing right?
garing
  • 998 Answers
SOURCE: My Kenmore Progressive canister vacuum cleaner no.
check fuse
Posted on Aug 17, 2009
  • 694 Answers
SOURCE: when plugged into electric outlet(checked
If the power indicator is not working, and your outlet is okay, then the problem is going to be in the cord or wiring. Carefully check the visible portion of the cord. If there are any cuts, or insulation scraped away, take the machine to an authorized Aerus Electrolux store/service center replacement. If no visible damage, take it in and let them find the problem, and repair it. Your vacuum should have many years of use left in it. For the store nearest you, go to http://www.aerushome.com/storelocator/, type in zip code, and click "view dealer list".
Posted on Oct 04, 2010
  • 694 Answers
SOURCE: vacuum does not have power and indicator light
This light is an indicator that the vacuum is getting power, so there's another problem.
First, turn the dial on top so the smallest dot lines up with the arrow. Then check the after filter beneath the tool caddy. Remove and/or replace if it's dirty. Try the vacuum now. If it still doesn't work, continue.
Turn vacuum off. Detach hose. Turn vacuum on. Does it run without the hose? If not, the control valve assembly inside the vacuum is bad and needs replaced. If it does run without the hose, place palm of hand over opening. Does it run? If it shuts off at this point, the tubes connected to the CVA are probably clogged and need cleaned. Either of these repairs need to be done by an authorized Aerus Electrolux service tech.
Other problems may include bad switches, broken/bad wires/connectors. There is the possibility of a burnt out motor, but it's not likely. The only way to get a definite diagnosis is to take the vacuum to an Aerus Electrolux store and have the tech troubleshoot it.
The nearest store can be found by clicking "store locator" at the bottom of the page on the site below.
aerusonline.com
Posted on Jan 04, 2011
SOURCE: I have a DC05 Motorhead model. The vacuum cleaner
In the handle is a loose wire; sits unde the switch.
Re-connect it and it will work again.
We had it several times already.
Posted on Mar 06, 2011
  • 694 Answers
SOURCE: Electrolux canister, maybe fifteen years
The light indicates the vacuum is getting power, not only the cord is plugged in. If there's a break in the cord, other wiring, or bad connections, the light will also not light because the vacuum isn't getting power.
Have it checked over at an authorized Aerus Electrolux shop. The service tech can diagnose and tell you the problem, as well as provide an estimate. There should be no charge for this.
Use the below link to find the store nearest you.
Posted on Mar 16, 2011
Bag light wont turn off
Hi there! The vacuum may be still sensing dirt in the cleaner. Try wiping the area down in and around the bag port. Be sure you are replacing the bag with a genuine Hoover Type Q bag. Also, when assembling the bag remember to slide the red bag door lock to the right to lock it on. If the check bag indicator light still comes on there may be an issue with the sensor on the vacuum. We would recommend taking your vacuum in to a Hoover authorized service center for repair. Hope this helps! Service Center Locator
Sep 13, 2014 | Hoover Platinum Collection Upright Vacuum
Green light but won't start
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Electrolux canister, maybe fifteen years old, green light indicating cord is plugged in is not lit, nor will the the vacuum turn on. Model 2100 Omni-flow automatic, number on bottom of unit F14970F. Thank...
Mar 16, 2011 | Vacuums
The Orange "ON" indicator light
We need lots more info...oil won't heat ?...is this a vacuum cleaner ? Pop corn popper ? Oil filled radiator heater ? Company name...model number...anything ?? Help us help you. Thanks.
Nov 06, 2010 | Vacuums
How do you install the belt on the kirby vacuum?
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Nov 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
