Question about Hitachi Drills
How do I release the bit from my Hitachi cordless drill
    Top Expert:
  • Hitachi Master
  • 8,150 Answers
  • 18 Answers
SOURCE: drill
the chuck should be in two sections. hold the bottom section and twist the top section to the left to undo.
Posted on Sep 19, 2008
  • 74 Answers
SOURCE: Keyless Chick will not Release - Hitachi DS18DMR
It's best not to use the drill power and your hand to try and release. Or tighten for that matter.
Set the drill down, and try using both hands on the clutch.
If that don't work, try using vise-grips or channel locks.
If that don't work, whip out of the WD-40 and let soak and then try again.
Posted on Feb 10, 2009
  • 29 Answers
SOURCE: Hitachi Quick Release Drill problem
put a box end wrench 7/16 or a 3/8 over the bit. put the bit in a vise. Lightly tap the wrench with a hammer while holding the relase sleeve back. usually need 2 people. 1 to hold the drill and the sleeve and 1 to hold the wrench and hammer. try a little tranny fluid or wd40 in the chuck. don't use the painted bits. use onle the chrome ones
Posted on Jun 21, 2009
  • 2468 Answers
SOURCE: which drill bits for b&d cordless
you can use any brand of bit on the market,but you need to use the correct bit for the material you are trying to drill thru
Posted on Mar 21, 2010
  • 623 Answers
You can use any brand drill bits yes.
Walmart sells a B&D set for about 15 dollars last I knew.
Posted on May 14, 2010
I have a Hitachi WH 18 DFL cordless impact driver, which I love. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit do
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Jan 19, 2012 | Dewalt 18 Volt Compact Drill Kit
A bit is stuck in my cordless Hitachi DS18DFL keyless drill chuck. How can I get it to release?
There are always 2 different rings to the chuck grip surface, you always hold the back one and turn the front one counter clockwise.
You should be able to do this by hand.
But if it is really tight for some reason, you could use a channel lock pliers or even a pipe wrench if you had to, but both might leave some marks.
Feb 27, 2011 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
Chuck will not hold bits, How to change chuck
down inside the chuck theres a big flat head screw that should do it.
Nov 17, 2010 | Hitachi DS18DVF3 18 volt Cordless Drill...
Have a hitachi cordless drill that the chuck has become stuck and cannot remove drill bit
Soak it with WD-40 and let it set so the lub runs down into the chuck and then try...
heatman101
Mar 21, 2010 | Hitachi 18V Lithium Ion Cordless Hammer...
Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Dec 02, 2009 | Drills
Jammed short shank drill bit in ring grabber drill driver
Mix a little JB weld stick anything to head of stuck bit. let harden and pull the sucker out.
May 16, 2017 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Apr 07, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Jan 26, 2009 | Hitachi DS18DMR 18V 1/2" Driver Drill
Sep 30, 2008 | Drills
Drill
Jun 04, 2008 | Hitachi 12v 3/8" Driver Drill Kit with...
Drills Logo
138 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
