Question about Fender Music
Clean or replace sticky knobs on passport fender 150 pro?
    Top Expert:
  • Fender Master
  • 3,113 Answers
Clean first then if it still has a problem replace.
Posted on Dec 13, 2016
I use this for fitness classes. After 1or 2 songs -the music starts cutting out the power is still on the passport and i know my ipod is working correctly - what could be the problem ?
How is the iPod connected at the class?
The VIP channel will override the signal if a mic is connected.
Are you using the same cable for dance AND home?
Is the ipod getting interference at the class from a wi-fi signal?
See attachment. It might help. https://classrooms.at.ufl.edu/wp-content/uploads/portable-pa-system.pdf
Apr 21, 2015 | Fender Passport 150 PRO Portable PA System
Why do the fuses keep blowing
The obvious answer is that it is pulling too much current. The cause could be many things. First thing to look for is usually capacitors going bad followed by shorted transistors.
There no easy answers to this problem.
Often you can locate a shorted capacitor by looking for one with a bulging end or electrolite leaking.
Oct 08, 2014 | Fender Passport 150 PRO Portable PA System
Fender Passport Pro 500
Fender Passports are notorious for being badly built with poor reliabilty. Trade it in for a fiver and buy something of better quality.
Nov 01, 2017 | Music
Could a bad cable connection make a fuse blow in my fender passport 250, or cuase any problemmwith ouput from my speakers...?
A shorted speaker cable could cause this... however, what you do is to replace the fuse BUT wire a 150 Watt lamp in series with the power input... This acts as a resetable fuse for testing. If the lamp stays lit, you still have a failure.
Aug 12, 2011 | Fender Pd250 Passport Deluxe 250watt...
Fender passport 150 pro- Bought to uses for "Bike Nights" Plaing cd palyer in small retail parking lots. Volume is too low, when ever I try to put input level beyond halfway,,, I get...
You are in danger of popping the amp. The Fender passport 150 would be capable of covering about only a 20 foot by 20 foot area. If your area is bigger than that, you need more power and certainly bigger speakers. I would NOT recommend the larger Passport systems as the speakers are too directive for what sounds like your use... also there are reliability issues.
Aug 05, 2011 | Fender Passport Deluxe 500watt Sound...
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
What's the best way to connect a PC (with DJ software) to a Fender PAssport 500 PRO (I want stereo input)?
Best way is to use a 1/8 TRS (stereo) to 1/4 TRS (stereo) cable from the PC into the Stereo 1/4 inch jacks right below the RCA stereo input jacks.
TRS stands for tip-ring-sleeve which means the jacks have the extra "ring" over a mono jack.
Jan 28, 2010 | Fender Passport Deluxe 500watt Sound...
MY Fender Passport P250 went into protect mode. I changed the FUSE at the power supply with a new fuse. Still it is in Protect mode. How to fix this
This needs to go to the repair shop. The protect mode is turned on when either the power supply has a problem or one or both power amplifiers have a problem. These are often blown components.
These units are HARD to work on. To open you have to first remove then front panel before you can remove the back panel that has the power supply and power amps/heat sinks.
Compare repairs of these units to working under an automobile dashboard!
Hint: On startup, use a series 150 wat lamp to limit current while repairing. SInce these use a switching supply operating off the input line, use an isolation transformer for personal safety.
Oct 04, 2009 | Fender Passport Deluxe 500watt Sound...
Music Logo
76 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
