Question about Video Game Consoles & Games
I updated afallout 4 on my xbox one and it wont load what do i do
40A3-0000-0080-0300-8007-0070
Try to clear your system of the most recent patch:
"Solution 6: Delete and then re-download system updates
To delete and then re-download the system updates, follow these steps.
Note These steps delete system updates that are installed on your Xbox console.
  1. Press the Guide button and then select Xbox Home.
  2. Select settings and then System.
  3. Select Storage.
  4. Highlight your storage device (but do not press A to select it).
  5. Press the following buttons in the following order:
    1. Left bumper
    2. Right bumper
    3. X button
    4. Left bumper
    5. Right bumper
    6. X button
  6. On the Delete System Update screen, select Yes.
  7. After your Xbox console restarts, select OK to download and install the system update.
  8. After the system update is installed, re-download your Xbox Live profile and try to sign in to Xbox Live."
You may also be out of hard drive space if you're using a 4gb internal model Xbox 360. If you haven't already, find yourself a compatible USB thumb drive to insert, format and use as added memory.
Sep 07, 2014 | Microsoft Xbox 360 Console
Need to update but problem
Try a different game disc that is fairly new. This usually solves the problem. (I use Halo 4 install disc) Or you can try loading it from a USB. http://support.xbox.com/en-US/xbox-360/system-updates/system-updates-info has instructions directly from Microsft. If all else fails, call 1-800-4MYXBOX, a rep will guide you through.
Mar 16, 2013 | Microsoft Xbox 360 Console
360 wont load games just goes to 360 screen
This means that your console was not updated with the latest firmware to read Wave 4 games. To update your console, you have to join and sign in to Xbox Live and the system wuill automatically acquire an update to enable wave 4 games to run. Hope this helps.
May 12, 2010 | Microsoft Xbox 360 Console
Wont load games
It sounds like the dvd rom is failing inside the unit. Please give Microsoft a call for a free replacement:
1-800-4-My-Xbox
Dec 02, 2009 | Microsoft Xbox 360 Console
Froze with fable 2 after downloading
YOUR INTERNET SPEED IS IMPORTANT. GOTO SPEEDTEST.NET THAN CLICK ON THE GOLD STAR, HERES WHAT YOU NEED LESS THAN 60 PING 500MB DOWNLOAD, 546KB UPLOAD.
ONCE YOU SOLVE THIS, DOWN LOAD LIKE ALWAYS. BEFORE YOU PLAY EREASE ALL UPDATES. THAN REINSTALL UPDATES. START A NEW SAVE.
IF ALL THIS FAILS. GOTO XBOX.COM THAN SUPPORT, REPORT THE BAD DOWNLOAD. HAPPY GAMING HOPE TO SEE YOU IN GEARS OF WAR TWO.
Jul 07, 2009 | Microsoft Fable 2 for Xbox 360
Wont load dashboard
go into your xbox box and find a little plastic bag with a booklet that has a powering on symbol and go to the last page. there will be numbers 1-800____ and also visit xbox.com/support
Jan 16, 2009 | Microsoft Xbox 360 Console
My halo 3 says player failed to load content
hold down the sync button and turn on your xbox (while still holding sync) untill it boots all the way. now goto settings > memory > games > halo 3 and delete all downloadable content and boot halo 3 if you get an update allow it and if everything goes well you should be able to get to campagne and eveything then redownload all downloadable content. some updates mess with the DL content and the holding of the sync while booting clears all failed updates and redownloading should reconfig the files to work wih the update. Hope this helps.
Jan 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont load...
cleaning the lens usually helps with this. If you don't have the tools to do it, try using a can of compressed air. If that doesn't work the laser may need to be replaced.
Dec 03, 2008 | Microsoft Xbox® 360 Core System Console
Original xbox wont load and tray wont open
Ouch, horrible problem.
Try these:
1. hold the eject button for 30 seconds
2. leave the xbox off for a few minutes
3.try a new outlet[may not have enough power to do anything]
4.get a new power cord
Hopefully this helps
Dec 28, 2007 | Microsoft Xbox Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
