I need a farallon adaptor in order to use my Apple Laserwriter 360 with my macbook
Does the Macbook Air need to have the battery inside to make it work??
It should run without the battery if you have the power adaptor attached. Sounds like there is more wrong than just the battery.
Sep 14, 2012 | Apple MacBook Air
Apple Laserwriter 8500 paper light out, when there is paper in the cassette. Not blinking. Solid yellow.
make sure the usb lead connection is secure
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X
this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 06, 2011 | Apple LaserWriter 8500 Printer
Will not accept AC power
Try to charge it with different Apple charger. If your PC is under warrenty then you could call Apple Costomer Service and have them send you a new charger. The number is 1-800-676-2775.
Jul 07, 2010 | Apple 13" MacBook Notebook Computer ...
I have a video adaptor that connects to an S-video cable and then to my TV which is currently hooked up to my macbook laptop. When I try to connect the same adapter to a newer macbook, it fits the port,...
Yes. The S-video adapter is not supported on more recent MacBook computers -- those having NVIDIA graphics cards: MacBook (13-inch, Mid 2009) and MacBook (13-inch, Early 2009).
http://support.apple.com/kb/HT1562
Oct 23, 2009 | Apple Computers & Internet
Drivers for a C3200 Oki laser printer to go with an Apple MacBook
Do a google search, there are 3rd party drivers that work all sorts of old and odd stuff, the Oki sounds mainstream, the term is GIMP driver I think
Feb 01, 2009 | Apple LaserWriter 300 Printer
Macbook pro power adaptor fix
Under normal circumstances this should be covered by apple's warranty. I had a similar problem and apple changed the power supply without any questions. If you have an Apple Store in your area, you should schedule a meeting at the genius bar.
Jan 14, 2009 | Apple MacBook Power Inverter Car Adapter
12/640 Laserwriter - driver needed.
I had the same problem when I got a new computer with Vista. I just went through the available 600 DPI printer drivers until I found one that worked ok with the 12/640 printer. The driver I used was the Samsung 6000 PS. I have had no problems with it.
Nov 19, 2008 | Apple LaserWriter 12/640 PS Plus Printer
Macbook pro + IBM m4000
Depends on the connections you have on both. Most MacBook Pros have a DVI connector on the side. If the IBM projector takes that sort of input, then all you need is that cable.
If the IBM projector has a VGA input, then you'll need an adaptor from DVI to VGA.
(VGA input is standard monitor looking connector.)
Jul 26, 2008 | Apple MacBook Pro Notebook
Apple LaserWriter 8500 not turning on
There is a glass-tube fuse inside, near the power switch that blew on mine a couple of years ago. Being the curious type, I popped off the side cover to see if there was any obvious reason, loose connectors, burned resistors, etc., and found the blown fuse. Can't remember where I got the replacement, but think it was Radio Shack. It's a common type.
Dec 12, 2007 | Apple LaserWriter 8500 Printer
MacBook wont run from battery
Apple does have a battery recall/fixing procedure on certain macbooks and macbook pros.
The battery of a MacBook or MacBook Pro computer may:
  • Appear to have no charge (zero percent)
  • Be unable to power the computer by itself; the computer might work only when it is connected to the MagSafe power adaptor, which only shows a green LED
  • Appear with a black "X" icon on the menu bar
  1. Shut down, then remove and reinstall the battery. Test for the issue(s) again.
  2. Connect the MagSafe power adaptor (if you haven't already) and see if the behavior continues.
  3. If the issue(s) persist, download and install the Mac OS X 10.4.9 Update.
  4. If the issue(s) persist, Download and install Battery Update 1.2.
If, after installing the Mac OS X 10.4.9 Update and Battery Update 1.2, a black "X" still appears in the menu bar, contact apple by calling 1-800-MY-APPLE (1-800-692-7753)
Dec 06, 2007 | Computers & Internet
16 people viewed this question
jasbo
jasbo
